PATCH: NLTS + Valet + KnockCEL
Old Apr 10, 2009 | 11:02 AM
  #1081
D-VO's Avatar
Originally Posted by Timmay81
not sure what im doing wrong but ive tried the first 2 patches and done everyting down to the T by the instructions on here https://www.evolutionm.net/forums/4830835-post.html
tried 2 computers and cant get it to show up in ecuflash. anyone help?
What ECU is it for? Is the endian correct ("big" "little")
Old Apr 10, 2009 | 11:17 AM
  #1082
Timmay81's Avatar
stock 03. but evil_eagle helped me get it setup
Old Apr 10, 2009 | 11:55 AM
  #1083
wesside's Avatar
you need to set your user level to developer if you've got it setup right or you could always ask me or Josh (gear head) to take a look at it for you your up in the ut evo forum errr day
Old Apr 10, 2009 | 11:58 AM
  #1084
Timmay81's Avatar
i had it on devolper before i even started, but i couldnt get either of those roms to work
but jake ( evil_eagle) sent me his xml file and i repalced mine so its all good now
Old Apr 10, 2009 | 12:03 PM
  #1085
wesside's Avatar
Okay cool if you need any help in the future
Old May 20, 2009 | 03:48 PM
  #1086
tvor's Avatar
Originally Posted by Jack_of_Trades
Yeah you need the new ROM that Tephra posts up, thats what have the patch embedded in it. If you've done enough of them, it only takes maybe 5 minutes to do it. When I was testing some patches for Teph, I got a new version every day for a week. I got REALLY fast at them in no time.
He probably already has all of his XML files edited though, that way it is in fact a simple copy and paste ordeal.
Can someone explain why this is? I have my knock sensor disabled in my ROM vix hex edit, so I am hesitant to switch to a new ROM, but I want to apply the patch.
Can I not patch my current ROM so that it will work with the XML?
or I guess if someone wants to tell me how to disable the knock sensor by hex then that would work too
Old Aug 6, 2009 | 11:56 PM
  #1087
nads1978's Avatar
I'm converting my GT-A to manual but keeping the GT-A ECU. The ECU is 4 plug, 3 rows of pins.
Should the patch work okay?
Old Aug 20, 2009 | 05:18 PM
  #1088
tscompusa2's Avatar
96420008 confirmed working on my late model 04 that came with the same rom.
So far I only thoroughly tested the NLTS, but i will respond back after I test the other options out so you can green light it for others. My specific car would not run on any other rom.
Old Oct 1, 2009 | 09:18 PM
  #1089
3gEclipseTurbo's Avatar
i just downloaded the 94170008 but i dont see the NLTS feature, as to how i set it at the rpm i want.
Old Oct 2, 2009 | 12:01 PM
  #1090
D-VO's Avatar
Are you using the patched ROM? Did you copy the codes over to the xml? Also, make sure you have the user level set to developer.
Old Oct 2, 2009 | 12:50 PM
  #1091
ok thanks, as i understand the nltf feature i wont have to adjust my timing it will pull timing on its own?
Old Jan 6, 2010 | 02:13 PM
  #1092
FJF's Avatar
FJF
Apologies for bringing back an older thread, but I have a question. I use this patch and I would like to add the 2-stage knock light capability. I'm not a software guy. Intuitively, it seems like the latter lines of code need to replace the former:
<table name="KnockSum Required for CEL" category="Mods" address="480C2" type="1D" scaling="uint16"/>
<table name="KnockSum Required for Slow CEL (Low Knock)" category="TephraMod-V7" address="4823c" type="1D" scaling="uint16" />
<table name="KnockSum Required for Fast CEL (High Knock)" category="TephraMod-V7" address="4823e" type="1D" scaling="uint16" />
What else do I need to do to gain this capability? Is it even possible without running V7? Please explain it as if you're talking to a 5 year old. If this was already discussed and I missed it in my search, I'd appreciate a pointer to the post. Thanks!
Old Jan 6, 2010 | 03:43 PM
  #1093
Evo_Jay's Avatar
You have to use V5.1 or V7 to use the 2 stage knock light. Its the only way.
IMHO the 2stage kock light isnt a great feature. I dont like having to look and figure out if it slow or fast flashing before letting off. On V5.1 and V7 I usually set the slow knock light to a number you'll never see (ie 30), then I set the fast knock light to the knock sum I desire.
Old Jan 6, 2010 | 04:02 PM
  #1094
FJF's Avatar
FJF
I appreciate the reply.
Old Jan 7, 2010 | 12:24 AM
  #1095
D-VO's Avatar
Also, since you asked: You can't get the two stage knock light by simply adding the definition, the ROM needs to be patched for it. Patching a ROM and adding a definition are two different things.
