PATCH: NLTS + Valet + KnockCEL
Old Sep 28, 2007 | 08:18 AM
  #256
bigric09's Avatar
Originally Posted by tephra
yep and then you need to use the .bin file inside the zip and copy all your current settings to the nlts-mod'd rom...
edit - follow the test proceedure to get a feel for how (and if) NLTS works on your car..
ok...so then just copy over my fuel tables and such ? my issue with that is, i have the jdm map sensor stuff in my rom, the idle control options.... im assuming none of that is in your 88590015 you posted. i was hoping i could just add your changes to my rom file, but i guess that wont work
Old Sep 28, 2007 | 08:19 AM
  #257
tephra's Avatar
no sorry - need to copy everything
Old Sep 28, 2007 | 08:24 AM
  #258
bigric09's Avatar
im starting lol....
do i have to continue to save it as a bin file ? or can i use the .hex extension
Old Sep 28, 2007 | 08:31 AM
  #259
fastrob691's Avatar
Also in reference to the sensitivity of the clutch switch, I made a mechanical mod to mine, I bent the bracket slightly to allow about 1/8-1/4 inch of movement before engagement. It's perfect now.
Old Sep 28, 2007 | 08:43 AM
  #260
bigric09's Avatar
im actually guessing the no lift wont work on my car because i have the clutch switch removed... is this the case ?
Old Sep 28, 2007 | 08:52 AM
  #261
bigric09's Avatar
i didnt see this posted either, but i copied all my info over to the .bin file that tephra supplied, in the table tephra mod options ... under my value column, they are all 1... im assuming 1 is on, 0 is off, can you guys confirm that
Old Sep 28, 2007 | 08:59 AM
  #262
kkarim's Avatar
Anyone tested Valet mode on the 88840016 yet?
Old Sep 28, 2007 | 09:00 AM
  #263
TTP Engineering's Avatar
65535 means you are using a ROM that doesn't have the code in it... or some other problem...
If you add the text to the xml and then open your existing flash, it will look this way.
If you copy and paste your settings to the bin itself, change the immobilizer code, it should look correct.
Old Sep 28, 2007 | 09:01 AM
  #264
bnice01's Avatar
v2 94170008 fix works like a champ, I can get results tomorrow for:
94170014
94170015
96940011
Old Sep 28, 2007 | 09:03 AM
  #265
C6C6CH3vo's Avatar
65535 means it didn't get edited or done correctly.
Struggle with it for a while before giving up and posting, you'll get it.
Old Sep 28, 2007 | 09:37 AM
  #266
bigric09's Avatar
i have been, .... i copied everything over to the bin, and i had recognizable values... as i posted a little earlier, mine said 1.... i tried flashing it to the car in a minute ago and once it go to the area of what i added, the flash failed....
im still thinking the clutch switch being disabled wont allow me to use the NLS anyway
Old Sep 28, 2007 | 09:38 AM
  #267
lilnaz's Avatar
could you elaborate a little bit, Im interested in changing it a tiny bit too
Old Sep 28, 2007 | 09:40 AM
  #268
accident's Avatar
If I got the first one to work without anyknown problems (96940011-nlts-mod-fix) should I still switch everything over to the new 96940011-nlts-mod-v2. I just spent over 30 minutes earlier switching my old maps to the first patch and then I just came across that you updated everything seems to work.
ed
Old Sep 28, 2007 | 09:50 AM
  #269
linuxman51's Avatar
Just got done updating the 008 rom with my info, bouta go outside and flash the ecu. Just for clarification, in the mod options, rev limit switching is valet mode right? 0 turns that off.
  #270
Pr3z's Avatar
ed
I have no plans to it works as it is.
If it's not broke why fix it?
