PATCH: NLTS + Valet + KnockCEL
Old Sep 28, 2007 | 07:38 AM
  #241
tephra's Avatar
also to the guys that paid me to patch their ROM I will be sending out new patches to you soonish - not tonight need to rest... hopefully on the weekend.
The bug isn't serious but annoying to me.
Old Sep 28, 2007 | 07:49 AM
  #242
Pr3z's Avatar
Originally Posted by TTP Engineering
96940011 UNTESTED updated with stock ROM!!!
Not working... Eternal service light flashing. Never shuts off.
Mine works. 96940011 On 1.31 and above. No issues, everything works as described. But I got the one before he updated it with a stock ROM.
I can upload mine with stock fuel and timing maps if that will help?
Old Sep 28, 2007 | 07:55 AM
  #243
evopower1021's Avatar
this might be just me but has anyone noticed that when you step on the clutch your bov goes off and then when you let off the clutch the bov goes off again?
so you hear it twice within a second......
weird!!!!!!
Old Sep 28, 2007 | 08:01 AM
  #244
TTP Engineering's Avatar
Using 1.30 here
  #245
C6C6CH3vo's Avatar
Tephra, AUD or USD for donation?
Old Sep 28, 2007 | 08:02 AM
  #246
bigric09's Avatar
Curiosity strikes....
can someone post the settings you are using for these rom changes so i can get a ballpark figure for each as to where i should be starting at... thanks guys.
also, im getting a number in the areas where i think it should be a yes or no. under tephra mod options im getting 65535, and just about everywhere there is a value that is what i see.
tephra, i will be shooting you some cash shortly, thanks for all you do
Old Sep 28, 2007 | 08:04 AM
  #247
4doorbullit's Avatar
Using 1.30 here
Hey ttp did yours flash at wot every single time? Because my is doing that. I havent logged it yet but it didnt feel like it was pulling timing. Im also using 1.30.
Old Sep 28, 2007 | 08:06 AM
  #248
tephra's Avatar
My settings:
TPS - 98%
Speed - 30km/h
RPM Drop - 1000
C6 - Either
I am going to look at the top clutch switch this weekend see what I can do to extend it... it really needs to "activate" just before the grab point of the clutch which is about 5cm down, rather than 1cm down...
Old Sep 28, 2007 | 08:09 AM
  #249
bigric09's Avatar
mine i set at
tps - 95
speed - 56
rpm drop - 1500
tephra, or anyone, when you get a sec, can you explain why im getting those 65535 numbers in the tephra mod enable disable column ? what should it be for on and off ?
  #250
rice_rocket88's Avatar
Donation sent!
I'm going to try the V2 on my ROM and patch it all again to see if it will solve my issue with the bogging.
My logs showed that with the stock (My existing tuned ) rom I wasn't knocking for the first few gears, but when I used the patched rom it gave me up to 4 counts of knock on 1st and 2nd gear....
Old Sep 28, 2007 | 08:11 AM
  #251
tephra's Avatar
65535 means you are using a ROM that doesn't have the code in it... or some other problem...
Old Sep 28, 2007 | 08:13 AM
  #252
bigric09's Avatar
i am using the 88590015 rom, i always have...
i was suppose to copy the table additions to my 88590015 xml im using already correct ? i added them to the end, just about the >rom line or whatever the last one is.
  #253
cossie1's Avatar
You need to use the 88590015 rom file thats been uploaded here
Old Sep 28, 2007 | 08:14 AM
  #254
tephra's Avatar
yep and then you need to use the .bin file inside the zip and copy all your current settings to the nlts-mod'd rom...
edit - follow the test proceedure to get a feel for how (and if) NLTS works on your car..
  #255
cossie1's Avatar
I take it there would not be an easy way to apply the patch to users current rom files ?
