PATCH: NLTS + Valet + KnockCEL
Old Oct 2, 2007 | 08:29 AM
  #406
chaz517's Avatar
bescause of al at dynoflash i cant do this. i uploaded my rom, and 1st of all it says 2004 when its an 05, and all my maps say INF or have crazy numbers, i tried ecu unlock buti cant do ****.so i cant transfer my maps to tephras, and cant even get the correct immbolizer code i dont think. it read 4201. no letters or anything. i cant even get 4201 to come up on tephras map under immobilizer code.
Old Oct 2, 2007 | 08:36 AM
  #407
Ralph's Avatar
You are probably using the wrong definition file.
Old Oct 2, 2007 | 08:58 AM
  #408
chaz517's Avatar
mellon tried to open it as well and no luck. any ideas on what i can try and how to do that? thanks i appreciate it alot
Old Oct 2, 2007 | 09:03 AM
  #409
mplspilot's Avatar
That's because he changed your rom id. You will need to change it back to what it should be through a hex editor. You will need to find out what the correct rom id for your car is and put it in the following address: F52.
Old Oct 2, 2007 | 09:08 AM
  #410
chaz517's Avatar
ok i will DL a hex editor and do that. where is the f52 address? how do i do that part? again i appreciate this sooo much, im not too happy with al
Old Oct 2, 2007 | 09:16 AM
  #411
mplspilot's Avatar
So about the RPM drop talk.... I got mine set at 500 rpms and i hit the limiter sometime when i shift slowly. But isn't bouncing on that limiter kind of good, cause it keeps the boost up? (i had no KC on my log when that happened)
Old Oct 2, 2007 | 09:26 AM
  #412
l2r99gst's Avatar
Your ROM ID should be 96940011
Old Oct 2, 2007 | 09:34 AM
  #413
chaz517's Avatar
so if i change that it will work? how do i change that though? although i did just talk to al and he said he will fix it later. so kudos to him. but in the mean time i wanna see if this stuff works lol, thanks for the help so far
Old Oct 2, 2007 | 09:41 AM
  #414
mplspilot's Avatar
^ no , it won't work. we're just kidding...... Of course it will!
Get a hex editor, you'll see what's what. If you don't, ask then.
Old Oct 2, 2007 | 09:48 AM
  #415
chaz517's Avatar
loll got some wiseguys up in here lol its all good. a downloaded a hex editor and i opened the rom and it was all a bunch of letters and numbers and weird stuff so im gonna try a differen tprogram
Old Oct 2, 2007 | 09:51 AM
  #416
chaz517's Avatar
i think i just dont know wtf i am looking at on this hex editor its confusing the crap ouuta me.. not literally tho lol
Old Oct 2, 2007 | 10:06 AM
  #417
tkklemann's Avatar
Is anyone having difficulty logging with EvoScan after loading these patches into their respective ECU's?
EvoScan wiggs out everytime I try to log with the patch.
When I re-load my ROM prior to loading in the patch, EvoScan works fine.
Any suggestions? I would like to not have to load an old ROM everytime I want to log..
Old Oct 2, 2007 | 10:17 AM
  #418
ohthree's Avatar
if i already have a prexisting flash from a vendor, what parts of the flash should i add to the roms that tephra offers? fuels, etc? could someone make a list? in my free time this week im going to run through and copy the obvious values and work out the kinks. any help would be greatly appreciated though! thanks.
tom.
Old Oct 2, 2007 | 10:26 AM
  #419
kreionic's Avatar
Everything logs fine for me with the evoscan
Old Oct 2, 2007 | 10:31 AM
  #420
Charlie_B's Avatar
^^ Same here.
