PATCH: NLTS + Valet + KnockCEL
Old Sep 30, 2007 | 10:45 AM
  #361
svtkiller's Avatar
Cool................... subscribed
Old Sep 30, 2007 | 10:55 AM
  #362
honki24's Avatar
log into your paypal account and click on the "send money" tab and put his email address (that he put in the first post) in the field and viola.
Old Sep 30, 2007 | 11:44 AM
  #363
travman's Avatar
Originally Posted by AlwaysinBoost
the only problem I see with that is, say you want to give your car to an inspection/service station for repairs/work. it will not pass a safety inspection with a flashing CEL and its pretty common knowledge a flashing CEL usually means stop driving and turn off the car right away.
This is exactly what i was trying to say...........
Old Sep 30, 2007 | 01:18 PM
  #364
NineWorks's Avatar
Done
Old Sep 30, 2007 | 03:04 PM
  #365
Charlie_B's Avatar
Anyone havings problems with massive amounts of knock (decreasing oct flag) when shifting? Ive got the drop set to 750, would raising that help? Im assuming that messing with the fuel maps wouldnt help, due to this being fuel cut. But what about the timing maps?
Old Sep 30, 2007 | 03:21 PM
  #366
nothere's Avatar
no knock on nlts on my car.
however I have worked my moderate load timing cells in the past. can you tell if it is the decel or the accel that is hitting you?
1000 drop
Old Sep 30, 2007 | 03:34 PM
  #367
Charlie_B's Avatar
Here is a log that starts with a launch. I had observed the knocking on the two-step, but my oct flag is normal by the time the car gets moving. With the NLTS, this isnt the case. I guess I just need to work those of areas of my tune out. Im going to try it out at 1000, as well.
And I just noticed how crappy the resolution is on today's logs. I was playing with it, and I think I need to change some settings back.
File Type: zip
Old Sep 30, 2007 | 04:10 PM
  #368
evo ippo's Avatar
Sorry for being such a noobie but can someone help me with getting this to work my ecu is 88590013 thanks guys for any help you can give me
Old Sep 30, 2007 | 04:42 PM
  #369
4TUN8's Avatar
I paypal'd some money to ya Dave.
Old Sep 30, 2007 | 04:51 PM
  #370
Jack_of_Trades's Avatar
Wow, that sure is some crappy resolution lol. Is your downpipe hitting one of the fins on your transfer case or the oilpan???? Its odd to get that exact amount of knock once the clutch is harshly engaged, which makes me think its drivetrain related.
Try doing a log while letting the clutch out nice and easy and see if it still knocks between shifts like that.
Old Sep 30, 2007 | 04:52 PM
  #371
recompile's Avatar
As far as knock on the two-step, do a slowww ramp to the two step, don't just floor it. The knock should go away.
Old Sep 30, 2007 | 05:16 PM
  #372
bigric09's Avatar
^ very true.... if you give it a few quick revs before diving into it, that helps as well
Old Sep 30, 2007 | 06:08 PM
  #373
Pr3z's Avatar
Did anyone elses ECUScan stop working after these modifications?
I get wrong integer error in Evoscan now, even when I go back to stock XML and stock flash.
Old Sep 30, 2007 | 06:30 PM
  #374
bnice01's Avatar
x2
Old Sep 30, 2007 | 06:32 PM
  #375
bnice01's Avatar
for six speeds I notice on 2 cars that NLTS 850-900 drop works pretty well. just FYI
i flashed in 1500 by mistake man LOL not cool, too much of a drop
