PATCH: NLTS + Valet + KnockCEL
Old Oct 2, 2007 | 04:56 PM
  #451
l2r99gst's Avatar
Originally Posted by logic
The only complaint I have (if you can even call it that; this is a huge improvement over what we had before) is that I'm very used to how NLTS on DSMLink and the code I wrote for our old 1g DSM worked: that is, rather than an RPM "drop", you have a fixed target NLTS RPM. So, rather than revving to 7000 RPM, then having an offset applied to current RPM for target shift RPM, you'd have an ideal target shift RPM set statically, so that no matter where you shifted, you'd get a consistent mid-shift RPM. Handy for the occasional freeway pull where you'd like to build a bit of boost before accelerating.
I used DSMLink NLTS as well, but actually I like the dynamic NLTS rev limit a bit better. I like it better because with a static limit, then you have to shift at the same RPM to get it to work well...if that makes sense. With a dynamic NLTS limit you can vary your shifting RPM and always have the same drop from that RPM that you are shifting at.
I've also noticed that, unless I set the TPS threshold very high, quick throttle blips when downshifting get squashed. (ie. You're at 3000 RPM in third, clutch in, blip the throttle to get the RPMs up, shift to second; NLTS as implemented here trips me up pretty good, because it doesn't allow engine speed to rise higher than 2500 RPM, while the fixed RPM version does pretty much exactly what you'd expect.)
Yes, you just have to make sure that your TPS threshold is high enough and you don't go past that threshold to blip the throttle for a downshift. A setting like 95% or somewhere around there shouldn't be an issue, unless you're flooring the throttle to rev match for the down-shift.
I actually like the TPS threshold compared to DSMLink, because with DSMLink the NLTS was active all the time and you could hit it shifting during normal driving if you went over the static NLTS limit. It was a bit of a pain, jerking around when you didn't want it to happen. Having a TPS threshold eliminates this to an extent.
Eric
Old Oct 2, 2007 | 05:00 PM
  #452
chaz517's Avatar
o nm i finally got it all to work but dont kno how to turn off the valet mode once its on. i got te holding the gas pedal down thing to turn it on,m but dont know how to turn it off, i tried hoilding it again and i hear the ecu click or something cliocks but it wont turn off. thakns
Old Oct 2, 2007 | 05:02 PM
  #453
logic's Avatar
*nod* I started off at the default 70%, which completely threw me. I have it at 90%, and it's less of an issue now, but I still trip it every so often. I'll give 95% a try and see if that works out better.
Old Oct 2, 2007 | 05:05 PM
  #454
fastrob691's Avatar
Same method used to activate it, gas floored car off key on for specified time. Mine worked fine
Old Oct 2, 2007 | 05:09 PM
  #455
cossie1's Avatar
Can anyone tell me which pin on the ecu the clutch switch is wired into please.
I need to somehow mount a switch on the clutch of my Evo 6, and connect it into the evo 7 ecu.
Old Oct 2, 2007 | 08:42 PM
  #456
Jack_of_Trades's Avatar
When you hold the gas pedal down to activate it, the CEL blinks really fast when its activated. Just keep holding your foot to the floor for an additional amount of seconds (whatever you set the activation timer for...mine is 5000ms). So, whenever you deactivate it, the CEL goes out
Old Oct 2, 2007 | 08:49 PM
  #457
chaz517's Avatar
ahh got it now nicee i wasnt holding it long enough, so i lowered it tp 5500 ms thanks. nstl is set at 1000 by the way worked better than 1500 in my opinion. whataa genius tephra is
Old Oct 3, 2007 | 05:00 AM
  #458
tkklemann's Avatar
Originally Posted by tkklemann
Is anyone having difficulty logging with EvoScan after loading these patches into their respective ECU's?
EvoScan wiggs out everytime I try to log with the patch.
When I re-load my ROM prior to loading in the patch, EvoScan works fine.
Any suggestions? I would like to not have to load an old ROM everytime I want to log..
Anyone else ave any input on this?
I believe I am still using EVOScan v.99.... (I think)
Old Oct 3, 2007 | 06:38 AM
  #459
Ralph's Avatar
What error message do you guys get with EVOSCAN now? Copy/paste it here.
Old Oct 3, 2007 | 06:42 AM
  #460
tkklemann's Avatar
I don't get any error messages, it does log, but all of my variables jump around something wierd. After it being connected, the car starts doing really funky things, as mentioned once by I thing Eric (l2r99gst) that it might be sending things to the ECU to run checks or something...
I am lost on this one, as it does it on my car, as well as a friends.
Old Oct 3, 2007 | 06:51 AM
  #461
bigric09's Avatar
mine did that as well... i had to uninstall evoscan and remove it from the registry and then reinstall it... also, do you have ecuflash and evoscan open at the same time ? maybe you have some sort of conflict with both programs and the cable ? not likely, but a thought.
Old Oct 3, 2007 | 06:57 AM
  #462
tkklemann's Avatar
I have tried uninstalling it, and reinstalling it, but did not remove it from the registry though.
I am very disiplined about not having ECUFlash and Evoscan open at the same time due to some conflicts int he past.
Maybe tonight I will try to do the complete uninstall/reinstall.
Old Oct 3, 2007 | 08:08 AM
  #463
C6C6CH3vo's Avatar
I wonder what tephra's going to come up with next?
Let him rest some, then we bombard him with donations to get him motivated.
Old Oct 3, 2007 | 08:39 AM
  #464
TTP Engineering's Avatar
96940011-
knocklight -works
NLTS- does not work, clutch switch input does not matter, TPS threshold alone triggers fuel cut.
Valet mode- works
Old Oct 3, 2007 | 09:04 AM
  #465
chaz517's Avatar
Originally Posted by TTP Engineering
96940011-
knocklight -works
Valet mode- works
everything for that rom worked perfectly fine for me
