PATCH: NLTS + Valet + KnockCEL
Old Jan 7, 2010 | 12:43 AM
  #1096
FJF's Avatar
FJF
Originally Posted by D-VO
Also, since you asked: You can't get the two stage knock light by simply adding the definition, the ROM needs to be patched for it. Patching a ROM and adding a definition are two different things.
Thanks for taking the time to comment.
Old Dec 19, 2010 | 04:05 PM
  #1097
deeman101's Avatar
I tried this patch on my car (96940011) and OMG WTF is going on! After a while of just sitting and idling the car starts going up and down on RPMs up to 2.5k and then eventually holds at 2.5-3k. While my wideband reads 18:1! And fuel trims, rpm, TPS, almost everything on my evoscan logs is all over the place.
I was watching evoscan as I drove and idled and it constantly showed fluctuating knock values (0-180ish). After reading the wideband log I now know it wasn't evoscan that was fritzing . Anybody else have this problem? I transferred all my maps as is from my old rom to here.
Here is my normal rom:
Here is the patched rom:
This is what worries me the most. Column R is wideband. When it goes up to 18:1 is when the rpm surge happens.
Old Dec 19, 2010 | 05:38 PM
  #1098
tephra's Avatar
You are better off using V7 - and using either 94170015 or 96530006.. depending what works best for you...
I cant remember this far back
Old Dec 19, 2010 | 10:08 PM
  #1099
deeman101's Avatar
Ok sure. I've been holding off on v7 cause of all the work but I guess this is forcing me to go now.
Btw when is SD 2.0 supposed to be ready?
Old Jul 16, 2011 | 04:25 PM
  #1100
evo6panama's Avatar
I have an EVO 5 and I've installed an EVO 8 ecu correctly, the problem that I'm facing is, if I use the Tephra V5 the stationary rev limiter works with no problems, even with the stock EVO 8 map works.
When I install the V7, I'm not able to make the stationary rev limiter work.
Also, I'm not able to make the NLTS work because of the upper clutch switch (it doens't have it)... Is there any way to make those 2 Tephra features work without the clutch switch?
tephra
Dec 26, 2023 01:11 PM
tephra
Aug 19, 2016 10:07 AM
tephra
Nov 3, 2009 11:55 PM
tephra
Jan 8, 2009 12:24 AM
tephra
Mar 18, 2008 06:22 PM
