Getting an error with EcuFlash
Old Oct 9, 2007 | 06:46 PM
Inprogress's Avatar
After turning the car on, connecting the cable, and hitting start datalogger on evoscan, I get this error...
Info: Waiting for INIT Response...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Connection successful...
Error: Unable to open COM1
The system cannot find the file specified
Info: Datalogger Ended.
What is going on?
Thanks
Old Oct 9, 2007 | 07:26 PM
kreionic's Avatar
Theres your problem dont have it on com port. Set it to USB cable FTDI-FT232
If you have a wideband go into the wideband settings and set the wideband and com port
Old Oct 9, 2007 | 07:46 PM
Inprogress's Avatar
Kreionic,
That was selected...
Any other options?
Old Oct 9, 2007 | 08:52 PM
Inprogress's Avatar
No one?
Old Oct 9, 2007 | 09:29 PM
23r0k001's Avatar
Originally Posted by Inprogress
No one?
Go to Device Manager under "Ports(COM & LPT)": and match the COM # to the software. At times if its not an onboard serial and you are using a OBDII USB conversion cable it will take another COM #, especially if you connect and disconnect often and also have other types of usb conversion cables(eg. USB>SERIAL). Usualy would be COM6. Anyway might have tried this but just making sure....
Old Oct 9, 2007 | 09:41 PM
Inprogress's Avatar
Thanks, I'll try this tomorrow and see if it helps.
I figured I wouldn't have to do this because the Tactrix cable is a straight up USB cable, there is no usb-serial adapter in the mix.
Old Oct 9, 2007 | 10:26 PM
Jack_of_Trades's Avatar
Make sure the wideband O2 sensor option isn't checked if you are't logging one. Thats my problem whenever I forget to plug in my wideband USB cable. Tactrix cables are 'auto find' so you don't need to select a COM, thats why it loads the tactrix files so it knows exactly what to look for with 100% compatibility.
Old Oct 9, 2007 | 10:37 PM
codgi's Avatar
^^ I'd bet that its the wideband issue. But also double check in EvoScan to make sure that "USB cable" is selected and not COM1 or Com2 in the upper left hand part of the UI.
Old Oct 9, 2007 | 11:36 PM
Inprogress's Avatar
Yeah, under items to Data Log I had selected Wideband A/F Ratio, I have one but just didn't want to because I dont have my USB-Serial adapter yet...
Thanks for this, I'll try it and let you know!
Nissan2Evo
Apr 5, 2013 05:00 PM
catman78
Oct 10, 2012 05:38 AM
mike86
Jan 20, 2010 07:04 PM
Adam@MMS
Dec 18, 2008 03:47 PM
dawnduran
Sep 9, 2007 08:23 PM
