ECUFlash Tune Milage and Mods
Old Oct 14, 2007 | 12:30 PM
JohnBradley's Avatar
For this particular ROM both the tables looked exactly like the Open Loop Load #1 table. I altered only the cruise are of the map in this example, but I have changed the whole map (1&2) to 45% and have no adverse effects.
Old Oct 14, 2007 | 09:45 PM
23r0k001's Avatar
great thanks!!
Old Oct 15, 2007 | 09:23 PM
scheides's Avatar
EvoM Moderator
Originally Posted by JohnBradley
NOW, go to your high octane fuel map and in the areas between 40-80 or so, alter them to 15.4-15.7 with 15.7 being a peak value at about 60% load.
Would you mind showing this section of your high octane map?
Old Oct 15, 2007 | 09:37 PM
PlanoEvo's Avatar
john with enough questions asked the market for the $200 ecu flash 20 hp will slowly disappear which it should. More people need to know that ecuflash is free and with a cheap cable and some basic searching alot of the simple tuning can be done diy and really the only pay for tuning needs to be done with turbo and cam upgrages or meth or water injection.
Old Oct 15, 2007 | 09:41 PM
SuPeRNeT's Avatar
Turn your boost down and add more timing... That will get you better gas milage as well.
Old Oct 15, 2007 | 10:26 PM
I will tomorrow...I dont happen to haVE it at this particular workstation
Old Oct 15, 2007 | 11:19 PM
Okay apparently I had enough time to get it done tonight so here it is:
and like Plano said I am steadily working myself out of a future job so please appreciate this.
Old Oct 16, 2007 | 07:05 AM
scheides's Avatar
EvoM Moderator
Great info man! Thank you!
Old Oct 16, 2007 | 10:02 AM
23r0k001's Avatar
In respoect to that; ECU Tunning was neevr as easily interfaced via USB. Then it was the problem of buying the the software which is now free. Logging software still costs cash. But as far as trusting a person to tell you what your car feels like; who better to do it then the owner.... :-)
Old Oct 16, 2007 | 06:25 PM
PlanoEvo's Avatar
I really guess I should've added you a latop or a computer within a few feet of the car. If no laptop then drag you pc to the garage and get a longer usb (male to female) cable. So the cable and logging software can be had for < $100. You have to ask yourself 1.Can you read 2. can you operate a computer 3. do you have a laptop or know some who does or a pc? If you can answer yes to those 3 than you can do exactly what all those mail in flash guys can do too. I come from the dsm community where if this access to tuning was as simple and cheap the $200 guys wouldn't exist. DIY save the money and get a wb road tune only when you've added enough extra parts making it neccesary. I have heard of far too many people paying too much money on tunes and even more that pay time again for retunes. John you will still have a job because you are smart and have skills and I think it only shows you kindness and willing help others without being greedy and that is always rewarded in ways far greater than cash.......
Old Oct 24, 2007 | 10:34 PM
Inprogress's Avatar
Thanks for this info, i'll see how these changes help, I'm getting real crummy gas mileage still (210-225 full tank w/mostly highway miles)
John,
Should I just log partial throttle then to get an idea of open loop?
Also, in your high octane fuel map you've adjusted the fuel up to 3500, you think there would be any adverse effects if I did this all the way to 4000 since I'm a 5-speed it would be more beneficial for me as im crusing at higher rpms at the same speed.
Old Oct 25, 2007 | 01:29 AM
evo828's Avatar
Have you also played with the Open Loop Throttle tables? What is their purpose?
Old Oct 25, 2007 | 11:14 AM
ohhgyeahfasho's Avatar
so what do the 5speed owners set it up to? i usually cruise between 3200-4000rpms..
Old Oct 26, 2007 | 04:09 PM
PlanoEvo's Avatar
Yes I am wondering what these tables are for as well?
Old Oct 26, 2007 | 05:22 PM
SWOLN's Avatar
+1 on the 5 speed 4000 rpm's.
