ECUFlash Tune Milage and Mods
Old Oct 26, 2007 | 07:36 PM
  #31
fryedchikin's Avatar
I played with this earlier and my O2Feedback data shows the ECU still running in Closed Loop even though the Load & RPM values indicate I should be in Open Loop. Car only has K&N drop in and the Open Loop Load#2 values are set at 45.0 from 2000 - 4000.
Any ideas ?
Old Oct 26, 2007 | 08:25 PM
  #32
PlanoEvo's Avatar
Did you try setting the load #1 table to 45% as well?
Old Oct 27, 2007 | 11:08 AM
  #33
inco9nito99's Avatar
To the best of my knowleged table #1 is warm-up.
Old Oct 27, 2007 | 11:11 AM
  #34
JohnBradley's Avatar
Like I said in the other thread, while it makes sense that its warm up I havent really seen any definitive proof. I do have both tables setup the same way.
Old Oct 27, 2007 | 01:00 PM
  #35
No, I have not made any changes to the Open Loop Load#1 table as I was also assuming this table is used during warm up. I will set both tables the same way and see what happens.
Old Oct 29, 2007 | 04:16 PM
  #36
Setting both tables the same did the trick, so it would appear Table 1 is not just for warm up....
Old Dec 14, 2007 | 10:15 AM
  #37
Smike's Avatar
I am about to start making my own MPG map.
So what has been everyone seeing for before and after results?
Also - did you make changes to the timing maps (lower timing)? Or does just leaning the fuel map do the trick (without adding knock).
Old Dec 14, 2007 | 12:40 PM
  #38
juyanith's Avatar
I went from about 21 to 25 mpg. The car was already tuned, just not optimized for cruising mileage.
Also - did you make changesto the timing maps (lower timing)? Or does just leaning the fuel map do the trick (without adding knock).
I only modified fuel (for mpg purposes) so no timing changes are needed.
Old Dec 14, 2007 | 04:21 PM
  #39
Smike's Avatar
Right-o!
I currently get 23-24 of mostly highway on my 93 map.
Sounds good. Ill just play with the fuel for now.
Old Dec 15, 2007 | 05:47 PM
  #40
I noticed tonight after setting both load maps at 45% that my coolant needle seems to fluctuate a LOT, no abnormal ambient temps, and can be replicated via turning on/off the HVAC. Kind of odd, does map #1 correlate to t-stat by any chance? Never happened when only map #2 was changed.
Old Dec 17, 2007 | 05:58 AM
  #41
Smike's Avatar
Did changing the open-loop #1 back to normal fix the problem?
t-stat is mechanical. But there are fans would turn on if the car thought it was overheating (or when you turn on the AC).
We got a foot of snow here in mid-Ohio (getting my Evo out of winter storage). I will be doing the MPG mod later today. If the same thing happens to me, Ill report back here.
Old Dec 17, 2007 | 07:45 AM
  #42
I cannot replicate it, and it only happened AFTER I changed both maps to 45%; before when I only had map #2 @45% it had never happened. Then again other than snow, there wasn't any noticeable difference in ambient temps. :shrugs:. I'm leaving both maps at 45 and seeing if it happens again.
Old Dec 17, 2007 | 10:19 AM
  #43
Smike's Avatar
I just did the af map and open-loop mods. Nothing happened here with the HVAC and temp gauge. Ill keep my eye on it though.
And I topped off the tank. I have to drive from Cleveland to Ann Arbor tomorrow - so I will have a good idea of MPG change by the end of that run.
Old Dec 18, 2007 | 01:42 PM
  #44
Smike's Avatar
For the 5sp guys - first testing the MPG mod on my car here. Just did 260 miles @ 3500ish RPM (about 75/80)...only got 23 MPG (normal). I did not change the values past 3500 on my af map. I have updated my map to the 4000 ranges. Ill post back with that data.
Old Dec 18, 2007 | 11:26 PM
  #45
UCB's Avatar
UCB
has anyone tried to log IDC for awhile to get a good average of fuel consumption before and after these mods?
