PTE 780cc Injectors Scaled - Piece of Cake
Old Oct 13, 2007 | 09:17 PM
tephra's Avatar
yep if you are changing any part of the fuel system you should really get a retune - or at least get a WB to tune yourself!
Old Oct 27, 2007 | 12:54 AM
recompile's Avatar
Just thought I'd let everyone know that I got exactly 20mpg on my last tank fill up after switching to 780's with the settings listed.
I'm on a new tankfull now, and I'm at 220 miles and my low fuel light JUST came on... I suspect I will have no problem getting more than 20mpg on this tank either
Old Nov 3, 2007 | 10:39 AM
Inprogress's Avatar
Originally Posted by ShamelessCookie
I referred to an old thread that had some data on scaling for various sizes of injectors based on AEM tables.
I went from stock to 780cc (the plan is to get a Green in the spring).
Made the following changes:
Did a couple logs and my AFRs are spot on, no changes to fuel map or MAF scaling (my MAF scale has already been adjusted for my intake)
I'm not sure about fuel trims, I'll have to log and see.
On a side note, my wideband just started reading funny... it's either full lean or full rich.. nothing in between. I think the sensor may be dead, but it's only ~6 months old (no race gas exposure)
ShamelessCookie,
Why are your numbers a little different? Did you have to adjust the scaling or is that what ecuflash just does? I mean instead of 1.369 you have 1.368 and instead of .600 you have .610, is that just what ecuflash did itself?
I'm getting this injectors installed in a few days and will be using your numbers, thanks for posting this info!
2.186 1.369 0.895 0.610 0.419 0.290
Old Nov 3, 2007 | 02:23 PM
recompile's Avatar
Originally Posted by Inprogress
ShamelessCookie,
Yea, EcuFlash requires certain intervals, so I entered the numbers from the chart and it auto-adjusted them
Old Nov 3, 2007 | 02:26 PM
JordanS4's Avatar
will this change if you have alcohol/meth?
Old Nov 3, 2007 | 03:21 PM
Jack_of_Trades's Avatar
No, just your fuel maps will.
jordo
Aug 22, 2007 07:13 AM
SPOOLEDTSiAWD
Mar 26, 2007 06:47 PM
dubbleugly01
Dec 23, 2006 01:52 PM
smokedmustang
Aug 4, 2006 08:52 AM
rraulston
AEM EMS
Jan 31, 2006 02:39 PM
