strange knok on high gears low rpms
Old Nov 14, 2007, 06:51 AM
mexevo's Avatar
I have just tried the nlts valet cel on knok patch, and i have found that i have cel flash on highway driving: these hapens sometimes on fifth and sisxth gear at about 3000 to 4000 rpms when i accelerate, i did a long list of logs in 3, 4, 5 and 6 gears at wot and i just get as much 1 or 2 counts and not alwais, i tried to get the mencioned knok doing long logs but i did not fownd knok but it stil flashes the cel sometimes on 5 or 6 gears at low rpms on higway driving.
the knok threshold is over 120 load and 4 counts.
in my wot logs i have never seen more than 3 counts
any ideas or just normal and nothing to worry
by the way i have not started to tune my maps so they are stock
Old Nov 14, 2007, 08:33 AM
mplspilot's Avatar
You hit too mucho boosto when you step on it at 3k rps in higher gears. Either downshift, or get it tuned out.
Old Nov 14, 2007, 08:55 AM
TouringBubble's Avatar
Exactly. More load on the engine and more boost at lower RPM. If the AFR is good then pull a little timing where the knock occurs.
Ferp
Mar 11, 2017 09:50 AM
740 Turbo Brick
Aug 24, 2016 11:44 AM
hattackk
Nov 18, 2015 06:15 AM
roni4g63
Nov 16, 2015 05:10 AM
Ludikraut
Jul 8, 2006 09:48 AM
Quick Reply: strange knok on high gears low rpms
