question about my tune
Old Nov 20, 2007 | 10:42 PM
itzcharlez's Avatar
hey so i got tuned by ivey a while ago.
i'm not sure what boost he set me at on the dyno but he told me to turn the boost on my hallman MBC down a bit cause the load on the street is different than the load on the dyno. When i first brought it out on the street the boost spiked to 24 psi.. thinking this was way too high i turned it down to 21 psi.
does this affect my tune in any way? would it affect my air fuel ratios? i'm not exactly sure what my air fuel ratio on the dyno i would have to check the map.
im really new to this whole tuning thing so i'm not sure..
thanks for your time.
Old Nov 20, 2007 | 10:44 PM
merkzu's Avatar
you need to set it so you hit the same boost on the street as you were tuned for on the dyno
Old Nov 20, 2007 | 10:48 PM
itzcharlez's Avatar
what if i dont know what boost i was set for on the dyno? can we improvise and assume that on a dyno jet it would be around 21-22 and off the dyno it had spiked to around 24?
Old Nov 20, 2007 | 11:14 PM
itzcharlez's Avatar
so... my other question is lets just say my car is tuned for 24 psi ish... if i turn the boost down to like 22 ish is that bad in anyway?
Old Nov 20, 2007 | 11:24 PM
lurkerpika's Avatar
well you might run a little rich
Old Nov 20, 2007 | 11:52 PM
itzcharlez's Avatar
so just a little rich?.. not enough to affect my car in a negative way. cause in my opinion 24 psi stock turbo is too much on 93 octane even if i was tuned for it. any other opinions on what i should do?
Old Nov 20, 2007 | 11:59 PM
JohnEB's Avatar
If you turned it down to 21 you should be fine. Get evo scan and log it.
Old Nov 21, 2007 | 12:02 AM
itzcharlez's Avatar
lol i would do evoscan but i'm really nood at ecu stuff so i have no idea what to do.. lol but if i should be fine then i'm not gonna worry about it too much...
i just didn't wanna pay for a tune and then go and mess up my tune by turning down my boost. =\
thanks again guys.
and sorry for the nooobness
Old Nov 21, 2007 | 10:04 AM
Mellon Racing's Avatar
check out www.mellontuning.com I have links and a video that discusses the equipment you need to check on your tune.
Old Nov 21, 2007 | 10:28 AM
Sean@Iveytune's Avatar
LOL!!!
Dear customer, you can PM me if you need any further assistance.
Sean
Old Nov 21, 2007 | 10:39 AM
mdsevo06's Avatar
I still don't think the question has been answered. If tuned for 23-24 and you turn it down to 21-22, what would happen to the tune. Run rich?
With winter here, do you need to re-tune for the winter and tune again for summer?
Old Nov 21, 2007 | 10:47 AM
itzcharlez's Avatar
thanks sean your the mannnn
btw i highly doubt you need a retune just becuase its getting colder out lols
Old Nov 21, 2007 | 10:53 AM
JohnBradley's Avatar
Everything else being equal changing the boost shouldnt make the car go rich. The car has to pass through 21psi at some point (and the corresponding load cell) to get to 22 or 24 or 45 and will be tuned. Ambient air temp can affect AFR's but not extremely drastically. Air density goes up as temp goes down so it will affect the tune. Does it require a retune? No not really unless the car was on the ragged edge or something (highly unlikely).
mdsevo06's Avatar
With colder temp. boost will rise. Tune during the summer at 21psi and you can see a spike of 23psi depending on temp. BTW, how would you know, your the one asking the question to begine with.
MitsuJDM
19
Nov 9, 2016 03:47 PM
Mellon Racing
194
Apr 12, 2012 04:45 PM
Johns_EVO_IX_SE
Oct 21, 2010 04:34 PM
mplspilot
E85 / Ethanol
135
Oct 14, 2010 05:39 PM
EVOVII_SWE
Aug 17, 2004 09:09 AM
