Help with Maps for Stage1+ VIII
Old Dec 11, 2007 | 01:54 PM
ViscoS2000's Avatar
I have had the car road tuned by Scot Gray and dyno tuned by Harmon Motive. I have continued to execute datalogging via Evoscan and have made refinements to my maps. I am running 91 CA gas.
My mods are as follows:
Work drop-in
2.75 in dp
RRE HFC
3in exhaust
Walbro 255 FP
Dejon MBC peak 22psi
I am installing Denso 720s (balanced by RC Engineering and HKS 272 cams.
I know that I will have to adjust injector scaling and have some preliminary settings for the injector latency voltages.
How should I adjust my initial retune to accomodate the cams? The goal is to adjust the fuel tables to make the car safely drivable. I don't have access to a WB O2 yet (as required for a complete tune). Should I run stock fuel tables, or just add a couple of points into my current tune? Maybe someone has a conservative base map for me to start with.
Thanks for any help.
Old Dec 11, 2007 | 10:12 PM
MZP@TeamD's Avatar
Former Vendor
For the precise tune especially when it comes down to fuel wideband is a must.
Old Dec 12, 2007 | 05:26 AM
MR Turco's Avatar
You will need a wideband to get your fuel trims correct.
Old Dec 12, 2007 | 10:11 AM
ViscoS2000's Avatar
A wideband is available for my use, just not at the time that my car is getting picked up after install. Just trying to avoid outrageous knock on the way home.
Old Dec 12, 2007 | 10:29 AM
MR Turco's Avatar
RC should provide some sort of ball park latency and scaling numbers. I wouldnt trust them for final numbers but they should get you home. I know deuchworks provides them. If not you may want to find someone with the same injectors and steal their numbers.
Old Dec 12, 2007 | 10:40 AM
ViscoS2000's Avatar
Thanks. I now have a plan of attack that will work for me.
Old Dec 15, 2007 | 07:49 AM
recompile's Avatar
You don't need a wideband for fuel trims... just a working front O2 sensor and a generic OBD logger such as OBD ScanTech.
This will tell you how much, in %, the ECU is adding or subtracting from the MAF reading to get the front O2 to read stoich (14.7)
Old Dec 15, 2007 | 07:55 AM
Ph3n1x's Avatar
True but it will make life alot easier...since you can force Open Loop mode and adjust the Scalings and Latencies faster than waiting on the trims to update.
Old Dec 15, 2007 | 09:29 AM
cfdfireman1's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=207924
Dynotech Tuning
Sep 20, 2016 01:30 PM
NOMIEZVR4
Oct 26, 2009 10:36 PM
loppad
AEM EMS
Oct 7, 2008 12:18 PM
nutrulz
AEM EMS
Aug 18, 2008 01:49 AM
PDXEvo
Aug 11, 2005 10:43 AM
