USDM Evo 9 ECU pinout here
Hey all,
I see in the above link from mrfred that pin 23 is 5v unknown load, has anyone tried to use it yet for a MAP sensor, as this would be so much easier than splicing into pin 42 for power.
also what changes in evoscan are needed.
thanks
Mike
thanks
Mike
bump, zip file does not work on both of my computers, followed this link from the wbo2 thread, and Im looking for where to connect the analog out from my AEM > evo ecu
http://evoecu.logic.net/wiki/USDM_IX_ECU_Pinout
Incase it comes up again
hi all just getting around to doing this im finally going to start logging my evo 9 and boy am i behind. quick set of questions. i looked at the pinout pdf file and if i am on the right track i'm suppose to put my analog wire of my lc1 to pin 73 right? also by doing this i am eliminating my rear o2 sensor? In my case the sensor on the cat converter? and if thats the case i would have to completely take the sensor out of the cat because the sensor will not heat up if i just leave it there right? thanks in advanced for the help.
