PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Dec 30, 2007, 04:21 PM
  #151
THUB's Avatar
Just got back form testing the 0008 rom. The ICS dwell worked, the valet worked, the NLTS worked, Slow knock CEL worked. Never knocked enough to see speedy. Tephra, you're the coolest dude EVER. Hope the everything is ok with your car. thanks for everything. I'll be donating this week.
THUB is offline
Old Dec 30, 2007, 04:22 PM
  #152
tephra's Avatar
thanks dude, can you tell me if the constant flashing CEL + ICS Spray came on straight away once you flashed?
Still trying to find out if 4.2 fixes that problem
tephra is offline
Old Dec 30, 2007, 09:35 PM
  #153
laakness's Avatar
Yep, 4.2 fixes that issue. I just did it this afternoon and everything seems to be working just fine! Thanks again.
Edit: btw, this is for 94170008
laakness is offline
Old Dec 30, 2007, 09:39 PM
  #154
tephra's Avatar
thanks dude, I will put up you have tested it!
Any other problems/oddities people want to bring up?
FYI - Looks like we have a theoretical solution for NON-ICS equipped cars - once we finalise and test it we will post up the info! I will involve wiring in a switch to the ECU.
tephra is offline
Old Dec 30, 2007, 09:51 PM
  #155
THUB's Avatar
Yup, the 4.2 did indeed fix those problems. Although, while trying out the NLTS again just now, I missed a shift and the revs shot to the normal limit, not my 1000 RPM drop I have set. And now I have a CEL for a vehicle speed sensor. I don't know if this is related but I figured I'd mention it.
THUB is offline
Old Dec 30, 2007, 09:54 PM
  #156
tephra's Avatar
Did you do the standstill NLTS test (ie set speed to 0km/h, tps to 15%, load to 30)...
tephra is offline
Old Dec 30, 2007, 10:48 PM
  #157
THUB's Avatar
No but it worked eariler on in the day. I'll try that tomorrow just to be sure it's functioning correctly.
THUB is offline
Old Dec 31, 2007, 02:03 PM
  #158
colo_evo's Avatar
tephra: your PM box is full!
is the correct paypal address donations@globalshare.net?
colo_evo is offline
Old Dec 31, 2007, 03:40 PM
  #159
Jack_of_Trades's Avatar
Yes it is.
Jack_of_Trades is offline
Old Dec 31, 2007, 06:49 PM
  #160
tephra's Avatar
sorry guys, I just heaps of PM's and I need to keep some of them for a record history sake
tephra is offline
Old Jan 2, 2008, 04:16 PM
  #161
laramie_05MR's Avatar
Thanks for all of your hard work again. Paypal ready
laramie_05MR is offline
Old Jan 3, 2008, 03:27 AM
  #162
Adamantium's Avatar
Tephra,
any chance of adding the changes to John's 88590015 Live mapping patch?
Am happy to add another donation when its all up and running, that said, I still haven't confirmed that NLTS-1 was working right.
Adamantium is offline
Old Jan 3, 2008, 04:34 AM
  #163
tephra's Avatar
Hi Adam,
We are still finalising the inputs for map switching, once we get that done then we can talk about colaboration of patches
tephra is offline
Old Jan 3, 2008, 04:37 AM
  #164
jcsbanks's Avatar
Adam, I'm still waiting for feedback from testers of the US Evo IX 88590015 patch with Tephra's previous version NLTS,knockcel,valet. I think given the complexities involved it would be better not to make further combinations yet until the issues are ironed out with live mapping (which is to evolve to DMA anyway soon).
Having said all of that, you are on the same ROM as me JDM UK Evo IX 88570008, and I haven't yet added the mods on my own ECU to Tephra mods yet.
Like Tephra, I'm trying to keep this focussed to avoid it all getting horribly out of hand with multiple out of date patches floating around.
jcsbanks is offline
Old Jan 3, 2008, 08:42 AM
  #165
Profoxcg's Avatar
tep.. did you get my e-mail ?
my V2 doesnt want to turn off the NLTS, is there a way to just delete the code for that feature or can you please help me fix it?
This is my solution for now... even with the value set to 0 it works so i changed the other values to higher numbers that i will never reach such as speed.... but I wish I could just turn it on an off with the actual switch, as a matter of fact for the future, turning it on an off on the fly would be awesome with some sort of switch.
Profoxcg is offline
Quick Reply: PATCH: KNOCKCEL+NLTS+AltMap (V4)
