Meth Failsafe and Patches
Ok, did some more logging. Don't know if everyone can see the 2929 data item I have, if you can't I can give you the code to add to evoscan so you can see this log. the standard timing maps are set to 13* in one huge block in both the high and low maps, the ALT maps are set to 20*. Notice how the ALT map seems to fluctuate between the standard and ALT map settings????
I'm adding a snapshot and CLCK HERE for a link to the .csv file
Yeah its switching, to some degree at least. I will try to log the map MUT soon and see if its fluctuating between maps or its legitimately switching.
When I tested the wires, I logged both 8928 and 8929. Only 8929 registered anything.
Just as suspected, its flip-flopping between the maps when the ADC input is getting 0v.
Any solutions Dave? CLICK HERE for the evoscan .csv file
I added a snapshot too
hehe.
OK u got mail!
I have removed the old "TPS altmap" selection code - shouldn't make a diff really.
also I have commented out the "ICS altmap" seleciton code.
Also new XML that includes a ADC0F threshold, I will fix the scaling (volts) later.
Let me know how it goes!
ps dont forget to copy your timing+fuel maps, as the default is nothing
OK u got mail!
Just tested v4.5, its stuck in alt map. FFFF0x8425 stays stuck at 03 no matter what. I confirmed that the ADC is still switching from 4.7v to 0v and it definitely is.
Ready for v4.6
(4 a.m. Rom testing FTW!)
Ready for v4.6
