Which WB?
Old Jan 8, 2008 | 11:18 AM
KazzEvo8's Avatar
Which WB?
I have an AEM UEGO but can put that in another car. I was reading how we'd have to make our own serial cables. I can do that, no problem, I used to make cables. But I don't need that hassle either.
I want good logging and I want to include the AFRs. But a lot of laptops don't have serial cables anymore, either. Which WB(s) are good and can be integrated into EvoScan/ECUFlash easily with a laptop? How do they work? Serial may not be an option for me.
Thanks!
Old Jan 8, 2008 | 11:22 AM
SilverShadow03's Avatar
Read Numbers 1 - 5 in the first post.... I think they should answer your question.
https://www.evolutionm.net/forums/sh...light=tune+evo
Hope this helps ya out!!
Old Jan 8, 2008 | 12:05 PM
KazzEvo8's Avatar
Thanks, but that doesn't really get at the crux of the question I was trying to ask.
Do I have to make a cable for any WB I purchase? Are they only serial communications-based? For instance, what's the Innovate use to hook into the computer? How about other WBs?
Thanks.
Old Jan 8, 2008 | 01:07 PM
TouringBubble's Avatar
Most still have serial connections. You can use a basic serial > USB adapter to connect to your computer.
Old Jan 8, 2008 | 01:45 PM
KazzEvo8's Avatar
I know those exist but I've heard of mixed results using them with some serial devices. Do folks really have that combination working?
Old Jan 8, 2008 | 01:47 PM
Mine works great. I got my adapter from Fry's and it's mounted in the car so I can connect easily.
Old Jan 8, 2008 | 01:48 PM
WagsEvo's Avatar
I have the serial->USB device above with no problems. Serial port cost me something like $2 and now I have AFR from my AEM UEGO through USB. No problem and sounds like the cheapest route if you already have an AEM WB.
Old Jan 9, 2008 | 07:11 AM
KazzEvo8's Avatar
Thanks! Off to get a cable!
Old Jan 10, 2008 | 04:22 PM
kkarim's Avatar
I have an Innovate LC-1, and it works great. It needs a serial port, but Innovate sells a USB to serial port, since apparently, they are not ALL compatible with the LC-1.
I suggest getting a USB to serial adapter, and trying out your AEM, if that doesn't work out for you, then look into another wideband...
Old Jan 11, 2008 | 05:31 AM
TeStUdO's Avatar
The Dynex serial to USB cable from Best Buy works perfect. Be sure to install the driver that comes on the CD sandwiched in the packaging though. If you dont look for the disk in the package, it's easy to throw out.
Here is the link to the cable: http://www.bestbuy.com/site/olspage....=1110263657278
Old Jan 11, 2008 | 07:29 AM
KazzEvo8's Avatar
Thanks, all!
