Running rich between shifts
Old Jan 8, 2008 | 12:51 PM
procircuitmike's Avatar
Hey guys Im having a prob with my car when accelarating hard and when i shift the car stumbles as i get back on the gas and goes rich 10.0 on my logs then clears out and continues to pull like mad till i shift to the next gear and it does the same thing again i have not done a boost leak test although i have replaced my DV because it was leaking at 10psi. I have also replaced the plugs with new oem ones it does this weather im running 28psi or 18. Any ideas ??
Old Jan 8, 2008 | 12:58 PM
GTLocke13's Avatar
Holy run-on sentence Batman!
I would do that.
Are you running an atmospheric BOV or just a different DV?
Old Jan 8, 2008 | 01:02 PM
I am recirculated with the new valve
Old Jan 8, 2008 | 01:07 PM
What are symptoms of a boost leak, the car boosts to 28 easily not sure how far it tapers though.
Old Jan 8, 2008 | 01:16 PM
GTLocke13's Avatar
I would post up a log and your maps if they're not vendor purchased. The boost leak test is just to eliminate one possible cause.
Old Jan 8, 2008 | 02:23 PM
What would happen if my stock boost solenoid caps were missing would this cause a problem with the ecu im running an EBC and noticed that the caps were gone from the stock solenoid.
Old Jan 8, 2008 | 02:25 PM
Evoryder's Avatar
boost leak and then contact mellon so he can adjust your maps.
Old Jan 8, 2008 | 02:44 PM
Slo_crx1's Avatar
It's the replacement valve that's causing it. I accidentally broke the nipple off my stock diverter, so I got a turbo xs aftermarket dv to replace it, and mine did the same thing no matter what. It's hard to deal with either way you go, you need a softer spring pressure than most aftermarket one's have to keep compressor surge down, but the tighter spring pressure helps keep your afr's closer to normal. Either go back to a stock type valve or try to have it retuned. I was able to play around with my map enough to get it higher than 10.4:1 like I originally had, but not by much.
Old Jan 8, 2008 | 02:58 PM
dont think its my tune when i do a log in third(without shifting) a pull to redline i have no rich conditions at all pulls clean all the way with good AFRs. It was doing this when i had the stock 9 valve on it thats why i switched cause it was leaking so bad. I thought that was surely it but it was not unfortunatly.
Old Jan 8, 2008 | 03:15 PM
I have talked to Chris about the problem and sent him logs but he had no clue what it could be but im going to do a leak test and see if thats the prob aleast it will rule out that if it is an issue when i get it done one step at a time i guess thanks for the help guys.
Old Jan 8, 2008 | 05:21 PM
Evoryder's Avatar
Remember you hit different load cells when shifting....Chris will be able to figure it out.
Old Jan 8, 2008 | 07:51 PM
GTLocke13's Avatar
Wow, I'm a retard...
mister1161
Mar 29, 2016 06:54 PM
tommyb123
May 31, 2015 12:18 AM
Riddle
Mar 26, 2014 11:15 PM
catman78
14
Aug 30, 2011 03:36 PM
LanEvo06
10
Oct 2, 2009 01:23 PM
