economy tuning
Old Aug 28, 2008 | 10:43 AM
  #331
mrfred's Avatar
Originally Posted by Jim in Tucson
Well, I'm not getting any knock.
No matter how much timing I add or fuel that I remove, E85 has not caused knock during cruise. In fact as the AFR is pushed leaner than stoich, the burn rate goes down (same is true for gasoline), and timing has to be further increased to make best use of the combustion event. Bottom line is that monitoring knock is not a useful method for trying to estimate AFR during lean cruise with E85 (or gasoline).
Old Aug 28, 2008 | 10:57 AM
  #332
Jim in Tucson's Avatar
Originally Posted by razorlab
I've had good luck with zeitronix. You don't even need to have the LCD screen if you are just logging to a laptop. Everything can be mounted behind the glovebox and nobody would ever see it.
I'd like to find a wideband that is/has a gage. By gage I mean something that properly fits in a gage pod. The only one close is the AEM UEGO. But, by this thread it appears to be less plug-N-play and more plug-N-pray.
Old Aug 28, 2008 | 11:03 AM
  #333
RazorLab's Avatar
Zeitronix offers a round gauge now, check out the website.
http://www.zeitronix.com/Products/ZR-1/ZR-1.htm
Old Aug 28, 2008 | 11:08 AM
  #334
TouringBubble's Avatar
The LC-1 is compatible with Innovate's XD-16 digital gauge. It's a shallow depth but does fit a standard gauge pod as well. Also, it's analog out channel can power any gauge that accepts a 5v signal.
Old Aug 28, 2008 | 11:43 AM
  #335
tkklemann's Avatar
Dynotune makes a nice, simple wideband set-up. It uses a *gasp* LC-1 and this:
This is what I use in my car, an LC-1 and the display above. It's really nice because it only displays a number, no gages or anything else un-needed.
It's a real simplistic set-up.
Old Aug 28, 2008 | 11:54 AM
  #336
RazorLab's Avatar
Yea those dynotune lcds are nice, do you know if you can use that with any 5v signal?
Old Aug 28, 2008 | 12:04 PM
  #337
Chemwarrior's Avatar
I like my LC-1.
Old Aug 28, 2008 | 12:39 PM
  #338
Are the digital gages actually readable? Meaning do the numbers bounce around too much?
The original LM-1 had little or no dampening and the numbers were simply not readable. Everything to the right of the decimal was just a blur.
Do all of these log to EVOscan with ease?
Old Aug 28, 2008 | 12:49 PM
  #339
Chabada15's Avatar
thy all run off the LC-1 so yes... and to respond to your other remark about AEM's i run an AEM and log it regularly, if people are too mentally inept to solder 2 wires together you shouldnt shoot down a product
Old Aug 28, 2008 | 01:58 PM
  #340
As I stated in the other thread ... the PDF instruction for adding the logging cable to the UEGO are incorrect ... they show the wrong serial plug and the diagram needs to be mirrored for correct wiring. I agree ... no fault of the product itself.
Old Aug 28, 2008 | 03:19 PM
  #341
fostytou's Avatar
EvoM Community Team
Originally Posted by tkklemann
Those look great put behind the normal OEM clock if you can live without it.
Old Aug 28, 2008 | 03:20 PM
  #342
Jack_of_Trades's Avatar
I run the Zeitronix gauge that Bryan posted up. I can switch between my EGT's, AFR's, Lambda values and boost levels with the push of a button. You can also have the outer LED ring be one item (boost,AFR,etc..) and the digital screen in the center be another. I like it.
Old Aug 28, 2008 | 06:30 PM
  #343
Chabada15's Avatar
that zeitronix is pretty dam evil no lie
Old Sep 13, 2008 | 02:57 PM
  #344
evo8dad's Avatar
Originally Posted by Chemwarrior
I like my LC-1.
What gauge is that? The Zeitronix? I've been looking for a 60mm a/f digital gauge but, haven't had any luck.
Old Sep 13, 2008 | 04:11 PM
  #345
It's this gauge right here.
http://www.innovatemotorsports.com/products/db.php
It's 52mm though.
