economy tuning
Old Sep 13, 2008 | 06:36 PM
  #346
Jack_of_Trades's Avatar
60mm gauges are hard to come by these days.
Old Sep 13, 2008 | 06:42 PM
  #347
Chabada15's Avatar
STRI of japan has a full line of both amber and white, Black Face DSD Gauges as well as regular gauges all available in 60mm...i love my DSD gauges...
Old Sep 13, 2008 | 09:18 PM
  #348
evo8dad's Avatar
Thx. I'll Google STRI now to see what comes up.
Old Sep 14, 2008 | 12:17 AM
  #349
Chabada15's Avatar
just go to Z1auto.com give them a call if you want talk to Adam tell him Chaz sent you...hes got the full line and there usually availible in like 2 days time from him...and his prices are pretty dam good
Old Sep 15, 2008 | 12:07 PM
  #350
evo8dad's Avatar
After looking their site, SRTI doesn't offer an a/f gauge, either 52 or 60mm :-( Still searching...
Old Sep 15, 2008 | 02:02 PM
  #351
Chabada15's Avatar
o if your looking for a 60mm AFR gauge your going to have a hard time...ive never herd of anyone offering 1...there isnt really a point theres a digital number n then the sweeping L.E.D. no need to make them bigger i guess
Old Sep 15, 2008 | 02:13 PM
  #352
RazorLab's Avatar
60mm and you can make it whatever you want:
http://www.plxdevices.com/products/dm200/
Old Sep 15, 2008 | 03:41 PM
  #353
Chabada15's Avatar
wow thats just for the gauge...dam gotta love PLX stuff tho...no joke products
Old Sep 27, 2008 | 10:21 AM
  #354
pltek's Avatar
i understand the narrowband simulation in closed loop, 0-1v signal coming from zt2. but what happens when you go to open loop? i maean at this point, ecu is looking at the map for afr but under normal circuimstances it would user front and rear 02 to adjust afr for things, so is the zeitronix simulating the front o2 sensor in open loop as well i guess?
Originally Posted by Jack_of_Trades
It MUST be cut. The only 0-1v signal NEEDS to be coming from the WB, not the stock O2 sensor or you'll fry stuff. Or......you can get an ECU pin and just unplug the stock wire and replace it with the ZT2 wire.
Old Sep 27, 2008 | 10:59 AM
  #355
Open loop = IGNORE the O2 sensor signal COMPLETELY. It only takes the O2 sensor signal into consideration during closed loop.
Old Sep 27, 2008 | 01:42 PM
  #356
pltek's Avatar
sure that makes sense, so can you just set me straight on this and tell me how the ecu (in open loop) then makes sure that afr is actually what is set in the map as well as any compensations for altitude, air density, etc/
thanks
Old Sep 27, 2008 | 01:46 PM
  #357
mrfred's Avatar
thanks
The ECU does not check the AFR in open loop. It blindly follows the AFR table and temperature/baro compensations tables with no feedback. That's why its called open loop.
Old Sep 29, 2008 | 10:46 AM
  #358
kmcconn9's Avatar
Can you just adjust the high and low octane maps for cruising speeds and not change the open loop values?
And you dont have to do the WB mod do you? You can simply change the values and log/watch the WB reading on the gauge correct?
Old Sep 29, 2008 | 04:03 PM
  #359
nothere's Avatar
kmc...
if I understand you, no
the car will stay in closed loop unless you switch off the tps and load open loop switches. (sort of double speak, but that is what you are doing.)
iow you can put 20 in the map and it will not have an effect unless you have closed loop "off".
of course MRfred has a more elegant way to handle this
Old Sep 30, 2008 | 07:53 AM
  #360
kmcconn9's Avatar
ok that makes sense. Thats too bad as simply adjusting the target afr in the fuel map would be much easier..not that adjusting the open loop condition is difficult.
