Brian Crower 280s and Mivec Map
Old Jun 6, 2008 | 11:21 PM
  #31
joedr's Avatar
EvoM Moderator
Check the AMS Cam Test Thread... the BCs are known for having to much variance and are needed to be adjusted to get them right.
So, the MIVEC map and the EX cam gear settings may differ from one set of cams to another.
BTW, retarding the EX gav me more TQ and better Top End based on DLL data.
Originally Posted by turboracer
What made you decide to retard the exhaust cam? Did you see a torque benefit? I'm running the same cams with the exhaust straight up right now. I used the mivec map posted in 22. I did smooth the advance around 1000 to 2000 rpm. I had a little off idle stumble on the map as posted.
Old Jun 7, 2008 | 12:48 AM
  #32
amak87's Avatar
does evoscan and mitsulogger read load differently? Thats what I have heard from a certain Dr.
Old Jun 8, 2008 | 12:37 PM
  #33
turboracer's Avatar
How much difference in torque and top end did you see?
Did you actually degree the cams into the motor?
What were your results? Or did you just adjust and log?
I would like to compare results and discuss them with Brian at some point. Maybe if enough people let him know the problems, there might be a fix from them.
Thanks
Old Jun 8, 2008 | 03:39 PM
  #34
joedr's Avatar
EvoM Moderator
I never got to get the BC280s to the dyno. But, I think that TQ was about the same but later on RPM and better top end on 4th gear. Mine is an MR! That is based on DLL logs.
Yes! I degreed the EX cam on the car.
It was a matter of trial and error. Different settings netted different results. On certain degree the car lost some top end but it was very responsive on low and mid range.
joedr
Oct 30, 2009 12:06 PM
joedr
Oct 22, 2009 11:49 AM
joedr
15
May 7, 2008 10:08 AM
joedr
58
Jan 13, 2008 08:49 PM
dan l
Jun 3, 2007 07:06 PM
