direct boost control in action
Old Feb 13, 2008 | 09:32 AM
  #31
Bonestock!'s Avatar
Originally Posted by bnice01
great results man keep it up.
hey j direct boost control is the way for any boost level. You have the gm 3 port, all you need now is the jdm map sensor to make it direct psi control. I'll hook your rom up like I did steven's. Once we get it dail in, its like that old saying "Set it & Forget it". I love ecu boost, even though I'm using target load instead of psi but I using Mrfred direct load (which is the shizzle). With the weather chaning alot with spring coming around, I always get the same boost. Boost error is doing its job LOL, with my mbc 27ish during the day 32 @ night.
Yeah so lets get mine dialed in. The difference between load based and target PSI is night and day. I'd never go back to a load based set-up.
Old Feb 13, 2008 | 12:29 PM
  #32
bnice01's Avatar
mrfred's direct load does pretty good, I love it.
Old Feb 15, 2008 | 06:03 AM
  #33
tephra's Avatar
i have noticed that if you leave the top correction at 0, then if you fall to much below your target boost it will never add onto the wgdc... I suspect if you dont want boost to ramp up quickly then set the top correction to +1 or +0.5 or something...
Old Feb 15, 2008 | 09:29 AM
  #34
mrfred's Avatar
Yeah, using 0 in top correction keeps the WGDC from getting racheted up during aggressive part throttle driving or during spoolup at WOT.
Old Feb 15, 2008 | 11:36 AM
  #35
spdracr's Avatar
will ecu boost control work with a aftermarket turbn setup with external wastegate?
Old Feb 15, 2008 | 12:25 PM
  #36
mplspilot's Avatar
Yes.
Old Feb 15, 2008 | 12:44 PM
  #37
RazorLab's Avatar
Yes, I suggest using a GM 3port in that application though.
Old Feb 16, 2008 | 03:27 PM
  #38
spdracr's Avatar
i got a JDM Map sensor that should work as well right? and are the tuning aspects such as WGDC etc. all the same even though im using an external gate.
Old Feb 16, 2008 | 05:23 PM
  #39
RazorLab's Avatar
Yes but smaller changes in WGDC will make larger changes in boost with the external.
richardjh
21
Aug 23, 2012 12:05 AM
silver_evo
Aug 30, 2009 08:46 PM
razorlab
Mar 20, 2008 11:28 AM
mrfred
Mar 19, 2008 09:13 PM
TouringBubble
Feb 13, 2008 10:37 PM
