evoscan 2.1 problems and fixes
Old May 2, 2008 | 10:30 AM
  #91
Wicked E's Avatar
Jack-
Do you change those trims to the proper display then or do you change the logreference?
-E
Old May 2, 2008 | 10:34 AM
  #92
Jack_of_Trades's Avatar
Originally Posted by Wicked E
Jack-
-E
Just the Log References, the actual Display names and request ID's are correct.
Old May 2, 2008 | 10:41 AM
  #93
Wicked E's Avatar
Thank you!
-E
Old May 21, 2008 | 02:35 PM
  #94
Jeff_Jeske's Avatar
I just downloaded 2.1 and its a CF. Can someone post a clean copy of the XML file?
Old May 21, 2008 | 03:54 PM
  #95
Wicked E's Avatar
Yeah hold on...
-E
Too long to post...
Old May 21, 2008 | 07:35 PM
  #96
Jeff_Jeske's Avatar
jeffjeske@jeffjeske.com
Thanks in advance.
Old May 21, 2008 | 09:31 PM
  #97
Jeff_Jeske's Avatar
..........actually I'm sick of dicking with this broke dick code.....
does anyone have a link to version .99?
Old Jun 4, 2008 | 03:45 PM
  #98
jvb6806's Avatar
i am getting an access denied message for COM port 1 when i try and connect the EFI portion in EVOscan. i can connect to OBDII and a few of the other ones but the readings are off and none of the gauges in the software work.
i know someone else earlier in this thread had a similar problem but i have the same message for a different reason. i am not sure if it is an EVOscan issue or an issue with the way things are set up on my computer.
at first by default my computer installed the link cable to COM7 so i changed it over to COM1 made sure everything in EVOscan was on COM1.
i pulled my maps just fine with ECUflash so i know there is nothing wrong with my link cable. and yes ECUflash was closed when i tried to connect via EVOscan.
there is a definite possibility that this is a newb mistake with a setting somewhere. i have searched for threads about setting up EVOscan but have not found any. if someone could point me in the right direction it would be appreciated.
Old Jun 5, 2008 | 08:26 PM
  #99
mountainturbo's Avatar
So I have version 2.2 and I have a question about the fuel trims...
For the formulas, this is what it says:
Is that right? The fuel trim low formula just says "x". Is the rest of it right too? (Specifically the STFT?)
Thanks
Old Jun 5, 2008 | 09:35 PM
  #100
The fuel trim low should have the same formula as the rest so be sure to correct that. The request ID's are all correct too. I didn't bother DLing v2.2 since it was riddled with errors and he has already announced a v2.3 in the very near future.
Old Jun 5, 2008 | 10:36 PM
  #101
Yah, I was trying to download 2.1, but once I installed it it showed up as 2.2. D'oh.
Old Jan 12, 2012 | 02:42 PM
  #102
HIONPSI04STI's Avatar
im getting this on my 04 sti and im using windows 7 starter
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Waiting for INIT Response...
Info: ECU ID: E4C7
Info: Connection successful...
Error: Index was outside the bounds of the array.
Info: Datalogger Ended
Jack_of_Trades
May 29, 2018 07:05 AM
lexa609
Sep 25, 2016 02:34 PM
canberkd
Mar 26, 2012 04:15 PM
Seijuro
Mar 20, 2010 11:53 AM
Mattjin
Apr 16, 2009 02:22 PM
