Drag log for you guys to play with
Old Mar 15, 2008 | 08:39 AM
JohnBradley's Avatar
They are both roughly the same and positive. Wouldnt he want to drop the injector scaling just a touch and see what happens?
Old Mar 15, 2008 | 08:59 AM
frenchy99's Avatar
Interesting on the intake temps - I wasn't sure if those were accurate or not, since it was nice and cool in the 60s.
I had thought the fuel trims were getting better, since we've made a lot of changes to the latency. What's still wrong?
What injectors are you running?
Old Mar 15, 2008 | 09:08 AM
Ph3n1x's Avatar
Looks like you have knock between shifts...you need to address that since more than likely its throwing an octane flag thus richening the mixture for an instance.
IMHO if there is no knock at all through redline ie 1-2 counts then the car is no where near the limits of the tune or the fuel you are using.
Old Mar 15, 2008 | 09:15 AM
Warrtalon's Avatar
You're right, it is not. we just started getting the DD tune right, and then I drove to sea level and hit the drag strip - not the best way to get a tune dialed in, hah. I don't knock on every shift - just the ones I botched. however, it seems I always get a quick lean spike after each shift.
Frenchy, FIC 850s.
Old Mar 15, 2008 | 09:34 AM
Ph3n1x's Avatar
Yeah keep playing with it, you'll get it in no time. Try to lower the ignition timing in from 0-100 load limits and from 6000rpm-8000rpm, to lower the knock tendancy through hard shifts.
Old Mar 15, 2008 | 05:13 PM
cpoevo's Avatar
Warr what are you doing in SD? You can try giving Reese Tuning a call. They are in San Diego. 619-749-0156. Hes got a DynoJet and might be able to help you out with the tune for sea level.
Old Mar 15, 2008 | 07:19 PM
Warrtalon's Avatar
Oh, don't need any help from a shop or anything. I have tuning support and am doing well, but I was looking to get some thoughts from EvoM folks.
I'm in San Diego at the SCCA Solo II National Tour - today and tomorrow.
Old Mar 15, 2008 | 09:06 PM
RoadSpike's Avatar
Frenchy, FIC 850s.
If your getting a lean spot between the shifts like i did with lean spool off then richen up the low load areas in the higher rpm range from 5000rpm and up between load areas 80 - 180. This flattened out the lean spike allowing boost to come on back quickly without knock and increased timing for me
Abacus
Sep 18, 2025 05:44 AM
supwiddiss
Cobb AccessPORT
Jun 24, 2016 01:21 PM
Warrtalon
Jun 8, 2008 08:38 PM
Warrtalon
Apr 2, 2008 08:56 PM
Warrtalon
Aug 26, 2005 11:15 AM
