PATCH: TephraMod V5
Old Apr 30, 2008 | 10:53 AM
  #496
kkarim's Avatar
for 88840017!!
Old Apr 30, 2008 | 05:35 PM
  #497
Racexerxes's Avatar
Old Apr 30, 2008 | 08:32 PM
  #498
tephra's Avatar
I will probably do a seperate 88840016 and 17 because the ROM's are quite different!
can some quick sole please tell me if the above two ROMs/cars have ICS?
Cheers
D.
Old Apr 30, 2008 | 11:14 PM
  #499
al\lupo's Avatar
88840016 has no ICS hardware.
What differences between 16 and 17 are you finding?
Old Apr 30, 2008 | 11:26 PM
  #500
tephra's Avatar
More than just a few map changes like 94170014 -> 15.
Well 17 looks like it has ICS code in it... perhaps the switch just isn't wired in... Usually when the ICS isn't there then the code isn't either
Let me look at the 16 ROM
edit - 16 ROM has ICS code as well!?!?!
hrmm.
Well I can put up the V5 for 17 and if people want to try it on 16 then its upto them..
I *will probably* work, but just be more careful with it
Cheers
D.
Old Apr 30, 2008 | 11:49 PM
  #501
al\lupo's Avatar
Yes, 16 has ICS code *but* no hardware.
I will be happy to try 17
Old Apr 30, 2008 | 11:56 PM
  #502
tephra's Avatar
first post update with 88840017
Old May 1, 2008 | 03:27 AM
  #503
PibusEVO's Avatar
Hello tephra
what I know is that 17 is an update of 16 with some changes in the rev limiter function.
According to what I read in an EU forum, the 17 will be updated directly during services since december 2007
Pibus
Old May 1, 2008 | 05:49 AM
  #504
tephra's Avatar
so dealers are putting 17 onto 15 and 16's?
if so then I wont bother with a 88840016...
Old May 1, 2008 | 08:35 AM
  #505
al\lupo's Avatar
I have little tested the modified 88840017 as update of 88840016; the car starts, it seems ok - but I have not tried on street.
Auto valet mode works fine; rear O2 sim seems ok, I must disconnect WB from ECU to test it properly.
NTLS and knock thresold will be tested next
Alt maps will take longer, I had no luck with ECU pins in Europe...
Old May 1, 2008 | 04:07 PM
  #506
tephra's Avatar
im actually using a bit of 14 (or maybe 16) gauge cable, fits snug in the hole and the ecu pin pushes into the end of it not stripped just cut straight and held in with tie's
Old May 1, 2008 | 04:17 PM
  #507
Jack_of_Trades's Avatar
Yeah, there impossible to find on EARTH! lol Yours will be on their way tomorrow
Old May 1, 2008 | 04:20 PM
  #508
tephra's Avatar
i'm still tossing up about removing the ICS features in 88840017 seeing as their is no hardware...
Old May 1, 2008 | 10:56 PM
  #509
al\lupo's Avatar
Tested NTLS and CEL on knock. All ok
For Alt maps I will wait the shipment from Jack.
Here in Italy the 88840016/17 are roms for GSR model (Recaro seats, BBS, no ICS, etc) while 88580014 is reserved for RS model (ICS and more rally-ready ). At the moment I have not found the 88840016 on RS and I suppose it is the same in EDM market (maybe with dfferent model name).
I think you can safely remove ICS stuff from ROM; maybe someone could add the hardware, but I don't have schematics to say how it is simple or difficult.
Old May 1, 2008 | 11:08 PM
  #510
tephra's Avatar
our IX's are 88580014... weird how mitsu chooses the ROMID
Ok i'll do up another version with all the ICS stuff removed..
