PATCH: TephraMod V5
Old May 7, 2008 | 11:57 AM
  #556
Oracle1's Avatar
Dave,
ROM 88570008 works perfectly, tried and TESTED! Notably UK cars have no hardware to support NLTS.
Very pleased!
Top Man!
Please update 1st page.
Regards
SK
Old May 7, 2008 | 01:23 PM
  #557
NineWorks's Avatar
Originally Posted by al\lupo
I have BIG issues with modified 88840017: there is something screwed in injector management... over 6000 rpm InjPulseWidth drops below 10 ms and AFR goes up to 18
Luck, luck, luck is: no knock and safe engine.
Tried to go back with map versions and the problem is with V5, I don't know why.
AFRMAP is costant and follow AFR map, but InjPulseWidth goes mad.
Note: Lean spool is off.
Tephra, MP your email address, I will attach a couple of logs and maps, if needed.
Any update on this issue Tephra ?
I had no time for testing 0017 V5 so far...
Old May 7, 2008 | 04:41 PM
  #558
tephra's Avatar
Originally Posted by scheides
Note: if you are using this with mrfred's direct boost control mod, simply change boost table #3 from this:
<table name="Baseline Boost #3 (BCLS)" category="Turbo" (ecu specific form here out)
to this:
<table name="Alternate Boost" category="Mods"
no dont use #3 (BCLS) there should already be a alt bdel table, you can just relabel and rescale that to match the boost tables mrfred has defined...
Old May 7, 2008 | 11:57 PM
  #559
tephra's Avatar
88840017 UPDATE
GUYS DONT USE THIS ROM, IT ****S YOUR AFR!
I have found the problem and a new version will be released very soon.
new version will also have the ICS code stripped
Old May 8, 2008 | 12:18 AM
  #560
tephra's Avatar
ok new version (5.5) of 88840017 is up, this also removes the ICS functionality.
so please remove any old XML you have
Old May 8, 2008 | 03:49 AM
  #561
jcsbanks's Avatar
Dave, pls tell us the faults you've found on various patches. It is educational.
Most of my mistakes with patches have been pointers and variable values.
Old May 8, 2008 | 04:06 AM
  #562
tephra's Avatar
no problems
for 88840017 there is two ROM locations that references the injector scaling, one at 0x16ecc, i accidentally overwrote 0x16eec...
so yeah - big mistake, my fault
kinda just reiterates why everything needs to be checked and tested properly
Old May 8, 2008 | 10:45 PM
  #563
mlocatel's Avatar
By the way tephra
how do yuo switch off the lean spooling in the 17?
I have an incomplete xml file
Thanks for the help
Marzio
Old May 8, 2008 | 10:52 PM
  #564
tephra's Avatar
nope
It's enabled 2500rpm to 7000rpm.
I am hoping allupo will look after the 88840014 xml for the next ecuflash release
Old May 9, 2008 | 12:18 PM
  #565
al\lupo's Avatar
88840017 V5.5 is ok; I miss the altmap test for now.
Tephra, why are you speaking about 88840014?
Old May 9, 2008 | 01:40 PM
  #566
Stealth Ag's Avatar
thank you so much for your effort.
Any clue when you will complete the 96420008 rom?
Old May 10, 2008 | 04:50 AM
  #567
tephra's Avatar
sorry al I meant 17.
sorry mlocatel I miss read your Q... will post up the xml latter
Ag - soonish
Old May 10, 2008 | 11:41 AM
  #568
taavisev's Avatar
is it normal that i cant see any % in TPS treshold?
in rom 88840017
thanx
Old May 11, 2008 | 03:01 AM
  #569
sub7's Avatar
Ok, here's my turn. I've been reading tephra mod v2, v4 and now v5, great work there! and so I am testing 90550001 ntls and alt map, both won't work as it supposed. I rather leave dave with his pile of "art work" and get some help here. Let's look at ntls first...
I think ntls might got to do with clutch switch and I did test ntls with 20%, 30% and 50% of load, 20% tps, 0km/h and 1000rpm drop. When I rev to 20% tps, my 2byteload is reading 30+ and the rpm drop 1000rpm unexpected. My foot is not resting or even touch the clutch pedal. So I increase tps to 95%, speed 30km/h and 100 load, then go for a run. At 3rd gear about 120 load, I throttle down 100% with my foot away from the clutch, rpm drop immediately. The clutch position switch is 2inch away from the stopper.. (pic can be found here). I dont think there's any other switch/sensor on the clutch? Should I bring up my clutch position? What's the criteria where ntls engaged? From my test, I believe either one of tps/load/speed AND clutch switch/sensor will make NTLS engaged.
Old May 11, 2008 | 03:39 AM
  #570
cossie1's Avatar
I don't think the evo 7 has 2 clutch switchs on it, the only 1 there is the 1 for starting the car with, and you need a different clutch switch to use with nlts.
However I am not 100% on that, best to wait for someone else to confirm, I do know NLTS works on this rom as barryc on here has wired up the switch to his evo5 and it works on his car using this rom.
I also use this rom on my Evo 6, and I use the external switch for ALT map's and again can confirm it works from the ADC0F connection on the ecu, again barryc has wired his car up to use the autoICS switch and his map switching works 100% from that too.
Have you got the correct setting in the tephra mod options table for the Alt Maps ?
i.e 1 if your using an external swith connected to ADC0F or 2 if you want to use auto ICS.
