PATCH: TephraMod V5
Old May 15, 2008 | 07:01 PM
  #586
4TUN8's Avatar
My car wont be running for a long time, but I still gave you a donation.
Old May 16, 2008 | 02:23 AM
  #587
cossie1's Avatar
Originally Posted by tephra
Can users of 90550001 tell me if their "AutoICS" activation of AltMaps works ok?
trying to fix a problem
I know BarryC has it working.
Old May 16, 2008 | 02:36 AM
  #588
jcsbanks's Avatar
Tephra, did you get chance to test "V6"? I've tried it on a few JDM 9 now with success, and Bez got it working on JDM 7.
Old May 16, 2008 | 02:53 AM
  #589
tephra's Avatar
not yet mate!
been vbusy with work and car stuff
Old May 16, 2008 | 03:13 AM
  #590
cossie1's Avatar
Is V6 the one with your live map patch to ram ?
If so, nice to hear thats it's working on the Evo 7 roms
Old May 16, 2008 | 03:21 AM
  #591
jcsbanks's Avatar
Well we sort of coined it V6, don't know if Tephra's V6 will simply be V5 + my stuff or have other stuff too.
Bez got the basic kernel of my DMA stuff working on his massively rewritten Evo 7 ROM. He was working on map tracing and also had the PC effectively running the maps instead of the ECU... he is using DMA to communicate the sensor variables to the PC which then calculates the ignition timing, fuelling and wastegate and sends it back to the ECU which behaves more like a dumb actuator. Crazy stuff, I think he was doing it to work on new engine management algorithms without rewriting lots of ECU code.
Old May 16, 2008 | 03:28 AM
  #592
cossie1's Avatar
Fair enough, but it sounds like a case of: So far So good
Old May 16, 2008 | 04:08 AM
  #593
tephra's Avatar
actually 5.8 will be out real soon... contains some code clean up + fixes for a bug or two + map averaging stuff..
V6 was going to be the PID controller for boost... but thats a little way off
Old May 16, 2008 | 04:40 AM
  #594
jcsbanks's Avatar
I have previous experience of writing PID boost control code for a microcontroller... 6 years ago so the memory isn't vivid, but the thread below will give you a lot of the development issues...
http://forums.nasioc.com/forums/show...hlight=diy+ebc
Old May 16, 2008 | 04:50 AM
  #595
jcsbanks's Avatar
I'll start a new thread and post the PID code that worked and save this thread for V5 if that is OK
Old May 16, 2008 | 05:07 PM
  #596
kkarim's Avatar
If i set the load threshold to the max, and the time to activate to 0, does this mean i will get instant transition both TO and FROM the altmaps?
What is the maximum load i can *READ CAN, NOT SHOULD* put in the load threshold?
Old May 16, 2008 | 06:41 PM
  #597
tephra's Avatar
dont set it to 0, might do funny things
max value you can put in there 20,000ish... but what would be the point... if you dont care about when it switches to altmaps just put in 350 or something...
Old May 17, 2008 | 09:20 AM
  #598
kkarim's Avatar
So if i want instant transition to and from my alt maps, putting a load of 350, with a delay timer of say 1 ms would be good?
btw tephra, did you check the email/pm i sent u?
thanks.
Old May 17, 2008 | 08:24 PM
  #599
tephra's Avatar
yeah i got it just been busy.
the above should work ok... if in doubt log it
Old May 18, 2008 | 02:07 AM
  #600
tephra's Avatar
hey guys,
there is a bug in 90550001 which prevents you from using AutoICS to get into altmaps.
Now BarryC has a working copy so I must have stuffed it up after giving it to barry hehe
so I will put up a new version tomorrow sometime.
Cheers
D
