PATCH: TephraMod V5
Old May 23, 2008 | 04:34 AM
  #631
Gpunkt's Avatar
ok thx,
i change the MUT to 04(0x8425) & 05(0x8929)
0x8425 works fine now but 0x8929 no signal
I will try on Monday the altmaps.
@al\lupo can you send me your xml file?
Old May 23, 2008 | 04:41 AM
  #632
tephra's Avatar
8929? whats that for?
8425 = 0 for normal maps, 3 for altmaps..
Old May 23, 2008 | 05:06 AM
  #633
Gpunkt's Avatar
Inpu voltage? like in this post?
https://www.evolutionm.net/forums/sh...4&postcount=75
Old May 23, 2008 | 05:30 AM
  #634
tephra's Avatar
depends on the ROMID...
anyways the above should be good enough unless it doesn't work
Old May 23, 2008 | 07:57 AM
  #635
al\lupo's Avatar
Sure, PM your email.
Old May 24, 2008 | 12:19 AM
  #636
taavisev's Avatar
bugs for 88840017
In ecu flash it does not show the TPS treshole
and RPMs does not fall down as i put the valu in the ecuflash only stays the same place where i push the clutch
alt map is not tested yet somewhere in next week
thanx
Old May 24, 2008 | 12:49 AM
  #637
tephra's Avatar
what do you mean it doesn't show the TPS threshold?
so you did the 2000rpm idling NLTS test?
Old May 24, 2008 | 01:08 AM
  #638
taavisev's Avatar
I cannot make the test!
because there is no nr in the place where i can change the valu of the TPS only dots... I can make u picture! abaut few minutes!
I was going with the hard way just testingi it when i was driving.
Old May 24, 2008 | 01:22 AM
  #639
tephra's Avatar
ensure you have
Code:
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16"/>
in your 88840017.xml someplace.
Old May 24, 2008 | 01:25 AM
  #640
taavisev's Avatar
its looks like this
Old May 24, 2008 | 01:27 AM
  #641
tephra's Avatar
yeah i think its an xml problem.
give what i said above a go and try again
Old May 24, 2008 | 01:33 AM
  #642
taavisev's Avatar
yee i can see now! there is numbers but i think nobody have it, because even in the new version of the ecuflash dont have it in the xml! where i can find the best xml file for 0017
have to go and test the RPM drop now!
thanx u the man
Old May 24, 2008 | 02:21 AM
  #643
tephra's Avatar
new version of ecuflash will/should have it in the evo9base.xml
yeah try rpm drop using the test procedure...
Old May 24, 2008 | 04:13 PM
  #644
justchil's Avatar
nm
Old May 26, 2008 | 12:38 AM
  #645
tephra's Avatar
I am going to release V5.8 real soon, over the next week or so, it will include a few fixes for things that are buggy as well some some minor new features.
I want to get peoples feedback about ROMID upgrades. Are people happy with the following:
88580013 -> 88580014 (confirmed by me :P)
88590013, 14 -> 88590015
94170008, 14 -> 94170015
88840013, 14, 16 -> 88840017
Any other ROMID's that I can put on that list? Or any objections to the ROMID's on that list?
