PATCH: TephraMod V5
Old Mar 18, 2008 | 02:47 PM
  #61
mfr122887's Avatar
Originally Posted by SuPeRNeT
I'm hoping for 96420007!!
Or 96420008! Tephra are you going to be doing either of these? Thanks
Old Mar 18, 2008 | 03:14 PM
  #62
Jack_of_Trades's Avatar
5 pages ad the first day isn't over,lol. This is gonna be one big thread.
Making the harnesses for everyone who ordered one right now so I should be plenty busy tonight Will get dropped in the mailbox this evening.
Old Mar 18, 2008 | 03:19 PM
  #63
SoCalRedLine's Avatar
^are you still out of pins for the IX ecu?
Old Mar 18, 2008 | 03:30 PM
  #64
Shadowpriest's Avatar
I don't quite understand the following statement in the directions for 88590015:
"4) Remove your current Hi/Lo Octane Fuel+Timing #2 and #3, only #1 matters anymore"
I have ECUFlash 1.34. I only show one high octane fuel and one low octane fuel map, and then the 3 high octane ignition maps and 3 low octane ignition maps as follows:
<table name="High Octane Fuel Map" address="2dbd">
<table name="Engine Load" address="6ec8" elements="20" scaling="Load"/>
<table name="RPM" address="6ea0" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="2ef5">
</table>
<table name="High Octane Ignition Map 1" address="33e9">
<table name="Engine Load" address="6f2c" elements="21" scaling="Load"/>
<table name="RPM" address="6efa" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3599">
</table>
<table name="High Octane Ignition Map 2" address="5523">
</table>
<table name="Low Octane Ignition Map 2" address="56d3">
</table>
<table name="High Octane Ignition Map 3" address="5a33">
</table>
<table name="Low Octane Ignition Map 3" address="5be3">
</table>
What about fuel am I supposed to remove? I gather that I am to remove the #2-3 low and high octane ignition table entries. It's fuel I'm confused about.
Old Mar 18, 2008 | 03:43 PM
  #65
MR Turco's Avatar
Originally Posted by MR Turco
If I am running ECU controlled boost, can i eliminate my #2 and #3 baseline boost tables as well?
edit: Another question, i noticed your O2 Sim Hook and Subroutine do not match Mrfreds from the other thread, is that supposed to be? Maybe you moved it to another place in memory?
because it got buried, anyone?
Old Mar 18, 2008 | 03:52 PM
  #66
They will be here in May. I should be one of the only people in the U.S. (among other countries lol) who has ANY. These suckers are near impossible to get, what a pain it was.
Old Mar 18, 2008 | 04:10 PM
  #67
MR Turco's Avatar
Time to start hacking apart totaled IX wiring harnesses?
Old Mar 18, 2008 | 04:15 PM
  #68
RazorLab's Avatar
Yes that is right. Only one hi/lo fuel. Three hi/lo timing.
Old Mar 18, 2008 | 04:16 PM
  #69
Or use the Evo VIII harness for now and I will send you the IX pin when they come in, free of charge. I have about 6-7 members using the VIII harness with a IX ECU right now. Its a tight fit in the unused pin location, its just that the VIII pin has no way to "lock" in so they just ziptie the wire to the factory harness to keep if from moving. Good enough until the pins come in
Old Mar 18, 2008 | 04:40 PM
  #70
tephra's Avatar
Yes you can remove #2/#3 BDEL's as well!
The O2Sim is the same algorithm as MrFred but implemented slightly differently
Cheers
Dave.
Old Mar 18, 2008 | 04:52 PM
  #71
Simply removing the Table's address and leaving it blank should be enough to disable it correct? That way it just grays out because its an incomplete table? Plus you won't be trying to access any particular ROM location so you can't screw anything up
Old Mar 18, 2008 | 04:54 PM
  #72
Evoryder's Avatar
The LED works but its not switching maps? If you have a volt meter, check the harness wire going into the unused location for voltage and see what readings you are getting. You can datalog the voltage at the ADC input in evoscan or mitsulogger. Unfortunately I don't know which address you'd need to use in your MUT table to do it, which ROM ID do you have? It was 0x8929 in my 94170014. The eval formula I used in evoscan was (x/256)*5 to read the voltage input. I just threw the 0x8929 in an unused MUT location in my 3D MUT Table. I believe MUT 83 shows the ALT map switching and will show a 0 when its in standard maps and 1 when its in the ALT maps. Worst case, I'll have you send that one back and I'll priority mail you a new one.
LED works fine. I'm using the same rom as you.... 9417004. I don't have a volt meter, probably get my hands on one and test it tonight or tomorrow.
Old Mar 18, 2008 | 04:55 PM
  #73
tephra's Avatar
Yes - sorry I should say:
With regards to "removing" 2/3 (timing/bdel/bwgd) its upto you, but probably renaming the table to something like "original name + DONT USE" might be best.
That way you can still "see" it, but you get a visual reminder not to use it!
Cheers
D.
Old Mar 18, 2008 | 04:56 PM
  #74
tephra's Avatar
Hey Jeff,
Can you log 0xFFFF8425 in a spare MUT?
0 = should standard maps
3 = altmaps
Cheers
D.
Old Mar 18, 2008 | 05:03 PM
  #75
Originally Posted by tephra
Hey Jeff,
3 = altmaps
Cheers
D.
Logging 0xFFFF8929 shows you the input voltages in bytes. It will register between 0 and 255. It should be 0 when its off (in standard maps).
