PATCH: TephraMod V5
Old Mar 23, 2008 | 07:05 AM
  #211
Jack_of_Trades's Avatar
Originally Posted by agron25
What is that is normal that I find these values
the probleme baterry voltage ? or good ?
thank
Change the BATTERY VOLTAGE address from 65D4 to 67F0. This is the correct address.
Old Mar 23, 2008 | 07:20 AM
  #212
John F's Avatar
i have these address in the xml ,but not work not
Is this what you have in your XML? This works for me.
<table name="Injector Battery Voltage Latency Compensation" address="37c0">
<table name="Battery Voltage" address="66f4" elements="7"/>
</table>
Old Mar 23, 2008 | 07:33 AM
  #213
agron25's Avatar
is good
thank
Old Mar 23, 2008 | 09:49 AM
  #214
</table>
66f4 is a 14 element table, not a 7 element table like you should be using for the battery voltage. Granted the first 7 values are the same in both, but the 67f0 should be the CORRECT Battery Voltage Table for his ROM ID(in my findings inside the disassembled ROM).
Old Mar 23, 2008 | 10:09 AM
  #215
John F's Avatar
Ok, thanks. Should the XML be as follows then?
<table name="Battery Voltage" address="67f0" elements="7"/>
</table>
Old Mar 23, 2008 | 10:55 AM
  #216
yeah, perfect I assume the values look fine in ECUFlash right?
Old Mar 24, 2008 | 05:00 AM
  #217
MR Turco's Avatar
Originally Posted by MR Turco
Tephra, i dont know if this was mentioned but i have my CEL flash set to 1000ms and it flashes for what must be 5 minutes. I have the 88xx15 IX rom. let me know if i can send you my rom because moving tables sucks JDM MAP, ECU controlled boost and tuned tables ftl Edit: i love the two different speeds of flashing though, very nice.
bump - it got buried.
Old Mar 24, 2008 | 10:13 AM
  #218
diiirk@AwdMotorsports's Avatar
If i mod my ecuflash and my map for these mods, and then my tuner retunes me, i would lose my mods right? i think i need to wait until im retuned to mod the map.
Old Mar 24, 2008 | 10:25 AM
  #219
fostytou's Avatar
EvoM Community Team
You would just need to supply your tuner with your XML file for your rom to use temporarily while he tunes you. If he can't work with that, then you probably need a new tuner
Either way, it would be pretty stressful on your ECU memory to go back and fourth every time you needed a flash, let alone to get the second map!
Old Mar 24, 2008 | 05:46 PM
  #220
tephra's Avatar
hrmmm - did you remove all the old xml? also what was the cel flash time before you changed it? I think it defaults to 2000ms, if it was some other number then check your endian
Old Mar 24, 2008 | 05:57 PM
  #221
MR Turco's Avatar
sigh, i feel like such a noob. I always check my endian too.... Thanks tephra
Old Mar 24, 2008 | 06:25 PM
  #222
tephra's Avatar
so was that the problem?
Old Mar 24, 2008 | 06:28 PM
  #223
MR Turco's Avatar
I havent flashed it but changing the endian made the number a lot larger then what i had. So i assume yes.
Old Mar 24, 2008 | 06:33 PM
  #224
tephra's Avatar
ok lets go back a step.
what was your endian before (for EcuTime scaling)?
what ecuflash version are you using?
Old Mar 24, 2008 | 06:37 PM
  #225
MR Turco's Avatar
my endian for ECUtime was big and i changed it to little. I am running 1.29a.
