PATCH: TephraMod V5
Old Mar 25, 2008 | 08:34 PM
  #271
draconx's Avatar
hey u f*ck. i sent you 15$! , probably sent more later on too
Old Mar 25, 2008 | 08:56 PM
  #272
Jack_of_Trades's Avatar
lol, you kiss your mother with that mouth? hehe
Old Mar 25, 2008 | 11:00 PM
  #273
draconx's Avatar
dunno about you but im not into that "keep it in the family" sh*t :P. lol
Old Mar 26, 2008 | 08:34 AM
  #274
Mojo Rising's Avatar
On the cheek...
You filthy, filthy man.
Old Mar 26, 2008 | 10:00 AM
  #275
silex's Avatar
I'm trying to build the harness myself, but I had a few concerns. I have a switch with a light built-in, but it's wired separate. Problem is that it needs 12v to work properly. I guess I can omit the 560ohm resistor as pointed out since this just lowers the voltage that passes through to 5v, correct? I'm just worried about feeding this line into the chassis ground pin on the ECU. I guess I can just grab the +12v ignition and ground somewhere that is closer to the switch. So only the single pin connection is all that is going to the ECU.
For the 'Alternate Map ADC0F Threshold', the default value is 3.01v. Does this mean that if the pin input sees a voltage higher than this, it will switch to the alternate map? I take it we can forgo a harness and just use a straight shot wire from the alky kit failsafe to the pin on the ECU? What if we want to hook up both, IE in the off position the system uses the failsafe, but at a flip of the switch, one can have a "manual override" that automatically switches maps? In either case, would the 'Enable Alternate Maps Faster' option still have to be set to 1?
Now that I think about it, the above sounds pretty dumb, lol...who would want to switch manually to a failsafe map? Hah... hopefully future versions will be able to add multiple alternate maps then the above feature will be useful
Thanks ya'll
Old Mar 26, 2008 | 10:20 AM
  #276
draconx's Avatar
lol
Old Mar 26, 2008 | 10:40 AM
  #277
fostytou's Avatar
EvoM Community Team
Some of the diagrams ans answers in this thread can answer (probably) all of your questions: https://www.evolutionm.net/forums/sh...d.php?t=330062
Old Mar 26, 2008 | 11:58 AM
  #278
silex's Avatar
Thumbs up
And thank you for the link!
Old Mar 26, 2008 | 02:42 PM
  #279
You can use a switch with an LED in it as long as it has 3 pins (12V in, 12v out and a separate ground input for the LED light).
yes indeed 5.0 volts is the maximum you want to send to the ADC input though.
Yeah you can but the alky kit needs to send 5v when the alky kit is working FINE, and 0 volts when a failsafe is triggered.
Thanks ya'll
You can have the alky kit directly wired and still have a "manual failsafe map" switch. All you need to do is put the switch inline between the alky kit and the ECU input. When you shut the switch off, its stopping the ECU from getting the 5 volts, so it will be running the failsafe maps.
The failsafe control unit I'm designing will have a bypass switch incorporated into it because there are instances where you would want to have that option. Say for instance you hear a funny noise with the alky kit or your AFR's are leaning out but none of the failsafe triggers are picking up an issue. Switch it to the safer maps instantly to prevent any real damage until you can take a better look at the issue. Thats just one example off the top of my head but I'm sure you can think of instances where it would be a good idea to be able to force the ECU to be on the safe side.
Old Mar 26, 2008 | 05:53 PM
  #280
ciobing's Avatar
I have tested my EVO 8GSR EDM V5.1 96530006:
Valet mode: ok!
Flash CEL on knock: ok!
NLTS: ok!
Alt Map: ok!
Alt Wastegate:untested
Alt Boost:untested
Alt Injector:tested only with equal cc/min
Tanks Tephra!Tomorrow I will make a donation
Old Mar 26, 2008 | 06:03 PM
  #281
tephra's Avatar
what do you mean you didn't test alt boost/wastegate?
did you just copy your regular boost/wastegate maps over the alternates?
Old Mar 27, 2008 | 02:56 AM
  #282
monsta's Avatar
Heres the EVO 7 GTA rom -Evo 9 GTA rom and two Airtrek turbo Roms for when you are not busy
http://www.mediafire.com/?3mz3yyzoiur
We "only" need cel/boost/valet.
Would be really cool to have map switching but that will proberly go into the too hard basket.
Thanks
Aaron
Old Mar 27, 2008 | 03:57 AM
  #283
ciobing's Avatar
because I use the Apexi avc-r for to manage the turbo
Old Mar 27, 2008 | 04:09 AM
  #284
tephra's Avatar
ok cool
just checking
Old Mar 27, 2008 | 04:24 AM
  #285
SEEnoEVO's Avatar
I have the same thing. So how do I go about having a different boost setting when the alky kit is powered vs when it is off and in the base map?
