PATCH: TephraMod V5
Old Mar 31, 2008 | 09:27 PM
  #331
fostytou's Avatar
EvoM Community Team
Just for people's future reference, I commented out the original BDEL table, changed this entry in the tephra section from
Code:
<table name="Alternate Boost Desired Engine Load" category="Mods" address="4a1e8" type="2D" scaling="Load8">
to
Code:
<table name="Alternate Baseline Boost" category="Mods" address="4a1e8" type="2D" scaling="psia8">
Now I see the proper psia units in the alternate table and don't even have to scale the values from the original. Schweet! Now as soon as my JDM sensor arrives I'll report back in!
(disregard the settings, I'm just getting into those)
Old Apr 1, 2008 | 08:54 PM
  #332
1idiot's Avatar
After reading 23 pages of wisdom i am lost. I watched the video for installing the patch into the rom and everytime i try to save the updated rom in rommetadata folder i get an error saying Cannot create the file. Make sure that the path and file name are correct. I know that i am being out smarted by the computer on a really simple level but for some reason i am just not seeing what it is. Any help would be greatly appreciated.
Old Apr 1, 2008 | 09:02 PM
  #333
tephra's Avatar
Vista?
try saving the new xml file to another location - and then use "my computer" or whatever to copy it into the correct location!
Old Apr 1, 2008 | 09:12 PM
  #334
1idiot's Avatar
Yeah its vista. So just resave it to the desktop the move it to the correct folder? Sorry i am slow tonight i am usually in bed 2 hours ago. Tephra this is looking like a simply amazing patch i only wish you had time to do some 1G DSM work. Oh and just as soon as i can get this done you can count on a donation from me, i just hate trying to guess what other peoples time is worth.
Edit: Tephra that got it thank you! I am gonna finish update and find some money. You are definitely a genius.
Old Apr 1, 2008 | 09:21 PM
  #335
tephra's Avatar
cool - since your a newbie (2 posts :P) just be sure to test the patch on your car before driving at full noise
not only will you find any bugs you will also learn how the patch works and what to expect (especially in relation to NTLS)
Old Apr 2, 2008 | 05:54 AM
  #336
MR Turco's Avatar
Nevermind, i need more review.
Old Apr 2, 2008 | 08:34 AM
  #337
Bonestock!'s Avatar
Wow.. now I see why Bnice was so excited. I read all 23 pages didnt understand most of it but then, thats why I have Bnice.
Old Apr 2, 2008 | 09:23 AM
  #338
bnice01's Avatar
tisk tisk bonestock LOL
Old Apr 2, 2008 | 10:10 AM
  #339
bnice01's Avatar
Ok went out and test 94170014 v5.1 seems to still have some type of turbo correction problem. My standard map target load is around 240 and my alt map is 290ish. Well switch to the alt map, and kept wondering why I could not get boost to pass 25lbs. Looked thru the logs and boost error is showing 19.8 (which is the highest it can read if you over boost) all the way thru the pull. In the turbo error correction table I have 19.8 pulling back 13% of wga duty cycle. I could have used v5 by mistake but I will download v5.1 again and report back or try 94170015.
Old Apr 2, 2008 | 01:57 PM
  #340
Steve J's Avatar
I'm in the process of copying my tables into the modded hex/bin.
I have a 'remedial' question that does not appear to have been asked. If I remove the #2 and #3 tables from the equation, which table do I apply to my tephra modded bin (that now only has #1 available)?
On my current tune...all three tables are slightly different in the 'High Octane Ignition Maps'.
I know this MAY be the answer but I still wanted to state it for anyone else that may have this question. My #2 and #3 tables appear to be the same. So I guess that answers my question?
Thanks for any input.
Ultimately I plan to 're-log' but still...just wanting to be careful.
Also - instead of 'marking' (in ecuflash) the tables #2 and #3 as 'do not use' as indicated in the video I modified the xml directly to remove the tables...is this okay to do or should I leave the xml alone and just mark the tables in the ecuflash program?
Sorry for such remedial questions...I just love the idea of having 'knock' sensor in my cel.
And THANK YOU very much for the VIDEO that was kick BUTT!!!!
Steve
Old Apr 2, 2008 | 04:15 PM
  #341
tephra's Avatar
hey b,
did you update your alt WGDC as well?
Old Apr 2, 2008 | 05:00 PM
  #342
fostytou's Avatar
EvoM Community Team
There are backups of the metadata files, but it is always good to back up and incriment each time you make changes so that you can go back if you need to.
Also, it is fine to change the name of the tables, delete them from the XML, or my personal preference to comment them out, and add a comment as to why you have done that. To do so, you wrap it in
Code:
<!-- (junk) -->
Old Apr 2, 2008 | 05:03 PM
  #343
chmodlf's Avatar
Not sure if the latest version of Evoscan does the same, but earlier versions did not like <!--comments--> in the xml for the fussy maptracer function.
Old Apr 2, 2008 | 05:42 PM
  #344
tephra's Avatar
yeah im pretty sure ecuflash and evoscan remove xml comments from the xml files
Old Apr 2, 2008 | 07:40 PM
  #345
Jack_of_Trades's Avatar
Steve
Your very welcome, I'm glad it has been helpful for someone at least,lol.
