PATCH: TephraMod V5
Old Apr 6, 2008 | 04:06 PM
  #376
bnice01's Avatar
lean spool is disable but out of all the 12 knock filter tables only 1 was different (the first one). More than likely after your post I will drop timing in the part throttle load cells a bit or adjust th knock filter back to 0008 standings. IDK I will keep messing around with it.
to be honest I dont think the old knock filter will "loose" knock count, since it has been doing its job pretty good over the past 5 years.
But thanks for the advance guys
Old Apr 6, 2008 | 05:38 PM
  #377
gear head's Avatar
Tephra, speaking of the knock filter tables:
When switching over to the 96530006 from 96940011, the filter tables #4 & #5 are drastically different. I'm assuming we should use the values from the 96940011 ROM.......just looking for some confirmation before I make the switch.
Old Apr 6, 2008 | 06:14 PM
  #378
tephra's Avatar
what does the sticky say about changing knock filter tables?
DON'T!
Anyways I would only be about 30% confident that the knock filter tables are defined correctly in both ROM's. Thus you could be changing something else!
Old Apr 6, 2008 | 06:30 PM
  #379
gear head's Avatar
Yah, I know thats what the sticky says, but wasn't sure if it applied when completely changing roms.Thats why I asked before I did it.
thanks
Old Apr 6, 2008 | 06:40 PM
  #380
tephra's Avatar
Old Apr 6, 2008 | 07:51 PM
  #381
bnice01's Avatar
i guess your right tephra, i just assume since I used those table before that I would use them again
Old Apr 6, 2008 | 08:47 PM
  #382
evodood's Avatar
Originally Posted by Jack_of_Trades
Originally Posted by silex
I'm trying to build the harness myself, but I had a few concerns. I have a switch with a light built-in, but it's wired separate. Problem is that it needs 12v to work properly. I guess I can omit the 560ohm resistor as pointed out since this just lowers the voltage that passes through to 5v, correct? I'm just worried about feeding this line into the chassis ground pin on the ECU. I guess I can just grab the +12v ignition and ground somewhere that is closer to the switch. So only the single pin connection is all that is going to the ECU.
You can use a switch with an LED in it as long as it has 3 pins (12V in, 12v out and a separate ground input for the LED light).
yes indeed 5.0 volts is the maximum you want to send to the ADC input though.
So can I grab any 12+ source and any Ground instead of those (in your diagram) at the ECU?
If so, the 12+ should be switched with the ignition on "ON" as opposed to a constant BATT. 12+, correct?
Old Apr 6, 2008 | 10:54 PM
  #383
fostytou's Avatar
EvoM Community Team
Yes and yes... unless you want a drained battery
Old Apr 7, 2008 | 08:15 AM
  #384
KillaItalian904's Avatar
I switched from 94170008 to 94170014, there are alot of differences in the open loop load maps. should i only copy my fuel and timing maps, init, immobilizer, and boost limit into the new rom 0014, or should i also copy the open loop load maps ? i have been doing these patches ever since the NLTS came up but i have never had to switch rom versions like this so im not sure if i need all that stuff in there, and i have never touched my open loop load maps
Old Apr 7, 2008 | 10:36 AM
  #385
Bonestock!'s Avatar
Originally Posted by rish197
Anyone using the 96530006 have any weird issues with Idle RPMS oscillating up and down when AC is on? I have double-checked all my ISCV settings. Not a big deal, but just thought I'd ask.
My 2cents so far...
2Byte works perfectly
Map Switching is amazing. Love having a lo/hi boost option!!!
No other issues I have found personally other than that idle issue.
Any update on ECU-based Direct Boost Control yet? No rush, just curious.
-Jason
Mine used to work perfect. Great when heading to the dealer for warranty repairs! BUT then I started getting throttle hang between shifts. After a quick play with the idle stepper tables, the hang is gone but my idle with the A/C isnt nearly as good as it was.
Old Apr 7, 2008 | 03:08 PM
  #386
tephra's Avatar
Killa - sounds like a definition problem! unless you changed your stock openloop maps then dont bother - if you did then get the definition correct
Old Apr 7, 2008 | 09:37 PM
  #387
evodood's Avatar
Sweet. thx.
Old Apr 8, 2008 | 10:16 PM
  #388
evodood's Avatar
Sorry for the noobish ? but my tuner is still running the CEL V2 mod and just want to make sure I understand the V5 CEL differences. If I understand this right:
"CEL on knock flash time" is the duration of blinking of the CEL when knock is detected.
"KnockSum Required for Slow CEL" = the min threshold to make the CEL blink "slowly"
"KnockSum Required for Fast CEL" = the min threshold to make the CEL blink "fast"
therefore if the "Slow" is set at 3 and the "Fast" set at 8; 3,4,5,6 or 7 knock counts will activate a slow blink and anything 8 or above with activate a fast blink as long as the load percentage is met?
Old Apr 8, 2008 | 10:43 PM
  #389
tephra's Avatar
correct
Old Apr 9, 2008 | 02:30 PM
  #390
Oracle1's Avatar
Dave,
Any idea on time frame for 88570008 rom?
Sorry for being inpatient but need the map switching...
Blasted noise limits for track days!!!???!!!!
Regards
SK
