PATCH: TephraMod V5
Old Nov 23, 2009 | 09:00 AM
  #976
fostytou's Avatar
EvoM Community Team
Originally Posted by merkzu
thanks, some of the tables (all the tephra mod stuff) seem messed up when I try and read with the 5.1 xml, was thinking maybe the v5 was different. Not a big deal, looks like the injector settings and fuel/ign maps are correct which is mostly what I was looking to get out of it.
Thanks
*facepalm* If something does not look correct you are probably doing it wrong and may be modifying the wrong values. Ideally you should switch to v7 anyway, but at the very least v5.10 which has some bugfixes from this version.
Old Nov 23, 2009 | 10:40 AM
  #977
merkzu's Avatar
I'm switching to v7, but have not touched my rom since v5 came out and didnt have the xml anymore. I needed to pull tables from my v5 rom to use in v7
Old Jun 16, 2010 | 04:11 PM
  #978
juanpdu's Avatar
tephra for 88840016 rom???? thanks
Old Jun 17, 2010 | 10:35 PM
  #979
D-VO's Avatar
Search your rom here: https://www.evolutionm.net/forums/ec...od-v7-123.html
Old Dec 3, 2010 | 09:19 AM
  #980
rrkpitt15's Avatar
Where is a wiring diagram for map switching? The pics on the first page do not exist anymore
Old Dec 3, 2010 | 02:35 PM
  #981
logic's Avatar
Mirror here: http://evoecu.logic.net/wiki/Map_switching_harness
Old Aug 15, 2016 | 09:38 AM
  #982
dalys8's Avatar
Looked for help in the official v7 help thread with no luck so I'm going to ask here (yes, I know this is a v5 thread). This is for my basically-stock EVO-8 (95170015). I converted my fuel/ ignition maps to big maps (and verified every cell made sense), copied my boost maps to the gear-based boost tables and the MAF parameters over, as well as all periphery bits being matched. The car starts fine, idles fine, even drives well under 2500 RPM, but as soon as I try to accelerate the car seems to knock lightly at LOW rpm, and then stalls very hard around 5000 RPM, almost as if fuel is cut as it cannot get over these RPM. During this stall I am getting significant intake popping noises. Should I anticipate some serious tuning to get these big maps in order, or is there something that I am overlooking? Anyone else have any issues with v7? All the other features work, such as valet mode, launch maps, etc.
Best,
-Shane
Old Aug 19, 2016 | 10:07 AM
  #983
dalys8's Avatar
Confirmed that 94170015 - V5 works with no issues.
richardjh
May 24, 2026 12:49 AM
tephra
Apr 22, 2026 11:03 AM
tephra
Dec 26, 2023 01:11 PM
tephra
Sep 13, 2021 01:07 AM
tephra
Jul 25, 2016 02:21 PM
