PATCH: TephraMod V5
Old Mar 22, 2008 | 12:02 AM
  #181
tephra's Avatar
yes MrFreds direct boost MOD will work with V5!
Old Mar 22, 2008 | 12:23 AM
  #182
draconx's Avatar
Originally Posted by Jack_of_Trades
The valet RPM limit isn't set below 1000rpm is it?
it was set to 114. is that stock? (like what tephra set it to). i moved it up to 1000. im gonna try it now. thx jack. :P
Old Mar 22, 2008 | 12:28 AM
  #183
Jack_of_Trades's Avatar
114 would be 114 RPM and definitely why it wouldn't start,lol. Setting it to 1000 will help determine if thats what the problem is, you still need to hold the gas pedal down for the set amount of time (set in your tephra mod options) to disable the valet feature before you can drive it over 1000 RPM.
Old Mar 22, 2008 | 12:31 AM
  #184
draconx's Avatar
alright ill go try that now then.
Old Mar 22, 2008 | 12:39 AM
  #185
NEW "HOW-TO DOWNLOAD and INSTALL the v5 PATCH" VIDEO in the beginning on this thread! (Post #4)
Hopefully I didn't mess any info up.
Old Mar 22, 2008 | 12:47 AM
  #186
draconx's Avatar
works now jack. thx
Old Mar 22, 2008 | 12:49 AM
  #187
No problem Glad I was helpful. Now make sure you go thru all f thse new settings for the v5 patch and understand what the settings all do. I'll be making a video explaining all of the settings this week hopefully.
Old Mar 22, 2008 | 02:00 AM
  #188
draconx's Avatar
oh. yea i kno exactly what they all do. thx though
Old Mar 22, 2008 | 02:11 AM
  #189
RazorLab's Avatar
but if you had the valet feature set at 0 (turned off, instead of 1) it wouldn't matter right?
Old Mar 22, 2008 | 02:16 AM
  #190
draconx's Avatar
yea it wouldnt. its set to 1 on default. i didnt think of un-checking it or looking at the values. (figured they were all set to a higher value. guess not though :P).
Old Mar 22, 2008 | 02:52 AM
  #191
PibusEVO's Avatar
Hello Tephra
In my car I have the 88840013 ROM. Will I be able to use the patch in the 88840017 that you are preparing, or these 2 are not compatible?
Best Regards from the EDM fraction :-)
Pibus
Old Mar 22, 2008 | 05:49 AM
  #192
tephra's Avatar
Hey Pibus,
you should be ok
but i will do a quick diff of 13/14/16 and 17 just incase there are major diffs
Old Mar 22, 2008 | 06:15 AM
  #193
PibusEVO's Avatar
I'm just looking forward to use the alternate map features .
If you need the .hex, please let me know
Pibus
Old Mar 22, 2008 | 08:06 AM
  #194
agron25's Avatar
I have just made out a will has l moment the no lift to shift
that works, is great
my id 96530006
Old Mar 22, 2008 | 10:38 AM
  #195
MR Turco's Avatar
Tephra, i dont know if this was mentioned but i have my CEL flash set to 1000ms and it flashes for what must be 5 minutes. I have the 88xx15 IX rom. let me know if i can send you my rom because moving tables sucks JDM MAP, ECU controlled boost and tuned tables ftl Edit: i love the two different speeds of flashing though, very nice.
