PATCH: TephraMod V5
Old Mar 20, 2008 | 12:02 PM
  #136
agron25's Avatar
my id 96530006 tephra
the units stock is good?
thank
Old Mar 20, 2008 | 12:16 PM
  #137
mplspilot's Avatar
I think you need to fix the endian.
Old Mar 20, 2008 | 12:21 PM
  #138
bnice01's Avatar
agron25 use the dowloaded prepatch rom for your rom ID ( 96530006-v5 mods.bin) and copy over all your info from your old rom ie fuel, timing, boost, scaling, IMMOBILIZER etc
looks like you used your old rom with the xml updated
Old Mar 20, 2008 | 12:35 PM
  #139
agron25's Avatar
ok
thank
Old Mar 20, 2008 | 01:24 PM
  #140
NineWorks's Avatar
Originally Posted by tephra
NineWorks/Kkarim - yes I will do 88840017 soonish
That sounds great !
Cheers, mate !
Old Mar 20, 2008 | 02:35 PM
  #141
Evoryder's Avatar
went back to my original rom 9417008 and 2byte works fine. will stick with it till teph either patches a rom for my ecu or figures out why 2byte don't work...take your time teph
Old Mar 20, 2008 | 02:38 PM
  #142
Jack_of_Trades's Avatar
Hopefully I will be uploading the "how-to" VIDEO's tonight so everyone can SEE how to do it, step by step.
Old Mar 20, 2008 | 03:58 PM
  #143
bnice01's Avatar
hmm were you using 0014 I take it with the MUT table?
Old Mar 20, 2008 | 04:02 PM
  #144
bnice01's Avatar
good idea bro
Old Mar 20, 2008 | 04:28 PM
  #145
dolphin888's Avatar
2 simple questions for you guys:
1) Can I really use 94170014 rom instead of mine 94170008 rom?
2) In the txt it's written:
Remove your current "Boost Desired Engine Load" #2 and #3, only #1 matters anymore
Q: Should I remove #4 as well ?
Old Mar 20, 2008 | 04:34 PM
  #146
bnice01's Avatar
yes you can use 0014, and yes delete max wga duty 2-4 as well as boost desire load 2-4.
Old Mar 20, 2008 | 04:40 PM
  #147
dolphin888's Avatar
Thank's for the info... I hope my ECU will not burn after I reflash 0014 instead of 0008
Old Mar 20, 2008 | 04:51 PM
  #148
More people than I can even count run 94170014 and 94170015 instead of the 008. My car originally came with the 008. Guess who installed my 94170014? The Mitsubishi dealership, because its a factory upgrade to solve certain CEL issues for P0300. 015 is supposed to be the same but with some VERY subtle tweaks as well.
If there is a fire, its surely not because of your ROM ID swap,lol.
Old Mar 20, 2008 | 05:08 PM
  #149
dolphin888's Avatar
If there is a fire, its surely not because of your RPM ID swap,lol.
Of course... I understand that.. anyway thanks for the confirmation, I'll try to reflash tomorrow morning
Old Mar 20, 2008 | 05:46 PM
  #150
dryad001's Avatar
So now getting back into the ECU thing again since the spring is near I have a few questions.
Ive done all of the .xml requirements and the new maps show up on my old .bin file, will I still have to transfer all of my old maps to the new one that I downloaded?
Sorry if this was asked already but didn't see it mentioned.
