PATCH: TephraMod V5
Old Mar 18, 2008 | 06:40 PM
  #91
Jack_of_Trades's Avatar
If you aren't using the 3D MUT table, you need the EXACT address for your ROM. The ones I posted are only for the 94170014 locations.
Old Mar 18, 2008 | 06:41 PM
  #92
tephra's Avatar
eeck - no.
if you are using the 3d mut_table then you should see groups of FFFF and XYXY.
You need to change the XYXY not the FFFF
Old Mar 18, 2008 | 06:48 PM
  #93
Evoryder's Avatar
For MITSULOGGER =
Code:
<Request LogReference="AltMapActive" RequestID="E3" Eval="x" Unit="unit" Logged="y" Response="2"/>
    <Request LogReference="AltMapVoltage" RequestID="83" Eval="(x/256)*5" Unit="Vdc" Logged="y" Response="2"/>
Unfortunately it shows "0" Volts for "AltMapVoltage" and a constant 255 for "AltMapActive"
Code:
AltMapActive	AltMapVoltage
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
255	0
  #94
BaLListic_EVO's Avatar
Originally Posted by Evoryder
no and no
maybe this is obvious, but have you changed the ecu flash option to "developer?"
yep it was on developer
Old Mar 18, 2008 | 06:49 PM
  #95
cossie1's Avatar
Originally Posted by tephra
eeck - no.
OH
Ok changed them back to FFFF
Is this the table you are talking about ??
Old Mar 18, 2008 | 07:15 PM
  #96
Yes it is, though your axis labeling isn't the most helpful.
Old Mar 18, 2008 | 07:20 PM
  #97
bnice01's Avatar
use 9417004 ...same as 9417008(my original rom id) ...they did mention earlier on this the post or some other post?
hold on, use 94170014 xml and its prepatch rom for 94170008 ID? just want to make sure thats right
Old Mar 18, 2008 | 07:25 PM
  #98
You can if you'd like. Even a 94170015 will work too with a 94170008 rom.
Old Mar 18, 2008 | 07:29 PM
  #99
bnice01's Avatar
CRAP, I dont even have my car to test it
its sitting @ the dealer getting the tranny rebuild
i always wonder if the other 03 rom ID's were interchangable like that, thanks for the info
Old Mar 18, 2008 | 07:32 PM
  #100
tephra's Avatar
going from like numbered ROMID's to others should be ok
ie
94170008 -> 14 or 15 should be ok
88590013 -> 14 or 15 should be ok
I would not attempt 90550001 -> 94170014 without some safeguards in place thou
Old Mar 18, 2008 | 07:33 PM
  #101
bnice01's Avatar
thanks for the tip tephra and jamie
hmm learn something new everyday
then why work on the 94170015, just curious?
Old Mar 18, 2008 | 07:36 PM
  #102
tephra's Avatar
what do you mean?
Old Mar 18, 2008 | 07:51 PM
  #103
bnice01's Avatar
FAQ
Will the KnockCEL flash if I already have a CEL?
YES
What happens if the car doesn't start?
Did you copy your Immobiliser code over? Please make sure you have copied all your maps over as well!
Did you remove any OLD XML in your definitions? Old XML incorrectly references code/maps so using it against the new ROM WILL cause problems!
ROMID's in progress - ie DONT ASK :P
96940011/96940015 - unfortunately this ROM doesn't contain enough space for V5 to fit, RazorLab is doing testing against OTHER Evo8 ROMID's to see if they work ok!
88570008 - soon!
94170015 - soon!
96260007 - soon!
96420008 - soon!
See you said "soon!" for rom id 94170015 but they are interchangable with the other 03 rom ID's. Just asking why do the work on 0015 if you can use 0014. thats all
Old Mar 18, 2008 | 07:52 PM
  #104
Shadowpriest's Avatar
So in the mean time while I have no harness should I keep the
"Enable Alternate Maps Master? ADC0F=1, AutoICS=2"
option set to 0? If I don't have the harness it just operates off the settings in my original map tables right?
Old Mar 18, 2008 | 07:54 PM
  #105
bnice01's Avatar
yes, until the IX harness is up
0 = not enable
