PATCH: TephraMod V5
Old Mar 18, 2008 | 07:54 PM
  #106
tephra's Avatar
Brandon - yeah well 15 is newer than 14 so I will get that one out as well
Shadow - well since you are 88590013/4/5 then you can only really do 0 or 1, and yes if you choose 0 it will just use your stock maps!
Old Mar 18, 2008 | 07:56 PM
  #107
bnice01's Avatar
Oh dont rush yourself, you have done alot for the evo community we are all greatful of it. I was just curious, I like learning
yeah once I get my car back from the dealer I'll test 0014 with my 0008. going to wire up the alt map switching to my failsafe, the Aquamist guys are going to love this mod using ecu boost (or any w/i kit with a good failsafe). Once the DDS3 detects a failure (or w/i kit failsafe) swith to the standard map w/ low boost (fail safe map). just have to set the alt map threshold so it does it no matter what load.
Old Mar 19, 2008 | 12:12 AM
  #108
evilempire76's Avatar
Ok, I'm a noob to this stuff and I'm trying to pick it up as best as I can so here goes.
What are we suppose to do with this:
NOTES:
1) Change your ENDIAN just below, ECUFlash version 1.31 and higher = "big", 1.30 and lower = "little"
Then it says:
Remove your current "Boost Desired Engine Load" #2 and #3, only #1 matters anymore
Ok so I understand that we need to delete "Boost Desired Engine Load #2 and #3. So does what I have boxed in red look correct as far as what needs to be removed?
Also I did the 2 byte MUT table and was wondering since I did that, then where do I need to post this patch into my xml file? Man I'm lost
Old Mar 19, 2008 | 01:12 AM
  #109
draconx's Avatar
pegasus. yes remove that. and also for the other one that he says to remove
Old Mar 19, 2008 | 02:32 AM
  #110
sba's Avatar
sba
When it will appear a 88840013/16 patch?
Or can i put another file instead???
Old Mar 19, 2008 | 04:15 AM
  #111
cossie1's Avatar
Originally Posted by Jack_of_Trades
Yes it is, though your axis labeling isn't the most helpful.
Any ideas what it should be like, and how it get it right ??
Old Mar 19, 2008 | 04:32 AM
  #112
chmodlf's Avatar
The 94170014 and 94170015 are very similar roms. There are only about a dozen or so values that are different. The 15 IMO is a small tweak from the 14 which was a substantial change from the original 94170008 rom for the 2003 USDM.
Tephra we appreciate your efforts!
Old Mar 19, 2008 | 06:15 AM
  #113
Shadowpriest's Avatar
Excellent. I will keep it at 0 then. I actually kept the #2/#3 tables in for BDEL, WGDC, and ignition. I tried to change their names to reflect that they aren't being used anymore and were only for show, but as soon as I did they wouldn't show up when I'd open the MAP file in ECUFlash. Weird.
Also, I am not up to speed on 2-byte MUT table. I am familiar with the other thread regarding how to set up 2-byte load on a IX ---> https://www.evolutionm.net/forums/sh...hlight=dummies
Is this still valid for your modified ROM?
Old Mar 19, 2008 | 07:28 AM
  #114
bnice01's Avatar
What if we have rom specific mods for our rom ID?
I dont know if 0014 rom is going to work with my rom mods on 0008 ie mrfred ecu boost mods
unless I can use 0008 settings for 0014 rom, I mean it seems like it would work just want to make sure thats all
Old Mar 19, 2008 | 10:09 AM
  #115
Evoryder's Avatar
Jamie - logged the address and it's showing zero volts and 255 always.
Old Mar 19, 2008 | 12:00 PM
  #116
chmodlf's Avatar
I dont know if 0014 rom is going to work with my rom mods on 0008 ie direct boost control
I think it should work. You will probably have to use different addresses though for the mods not contained in the V5. This is because of the significant differences between the 08 -> 14 & 15 roms. I think Tephra and mrfred and others are trying to not step on each other's code.
I am running the 94170008 and will be moving to the 94170015. I am going to skip the 94170014. It is going to take some time to sort out the differences though.
Sounds like we need a thread to coordinate all available mods to the early USDM 03-04 evos.
Old Mar 19, 2008 | 12:21 PM
  #117
bnice01's Avatar
Yeah your right, after I tried it I found out LOL but mrfred is half done with ecu boost mods for 0014. In the mean time I am going to use 0014 v5 and go back to the older load base boost.
Old Mar 19, 2008 | 12:45 PM
  #118
agron25's Avatar
i m test tomorow ID 96530006
Old Mar 19, 2008 | 01:14 PM
  #119
NineWorks's Avatar
I double this one :
Looking forward to see a 88840016 V5 here, tephra
Old Mar 19, 2008 | 01:57 PM
  #120
mr2driver's Avatar
I switched from the 88590013 to the 88590015 with the v5 patch. Everything went perfectly and everything works perfectly. Thanks for all the help and continued betterment of this vehicle and community.
