PATCH: TephraMod V5
Old Aug 4, 2008 | 09:49 AM
  #856
Cronic's Avatar
Originally Posted by evoredy
your computer's rom file/hard drive area where rom file is is corrupt, your ecu's memory is corrupt, or you had a usb/com communication event/error.
you probably had the latter. just test write or read from the ecu and try again. verify/check/reseat your cable device and its pins too. also, start from scratch with a newly downloaded rom file (if using Tephra's or the like).
Thx for the response!
Attached is the rom I have edited. If a second set of eyes can look @ this go for it. Lemme know if its all kosher...
File Type: txt
Old Aug 4, 2008 | 01:00 PM
  #857
j3llyh34d's Avatar
Well, I've tried again - with the exact same results. I think I'm loosing my marbles!
I can only get 96530006 to run if I completely disable the immobiliser. I've attached my updated XML and map.
Using scantech I get the following DTC info:
The map switching, valet mode, ICS linger work, but as before I have "slow flashing" as per fixem2
File Type: zip
Old Aug 4, 2008 | 02:33 PM
  #858
Mr. Evo IX's Avatar
I'm currently tuning a IX with HFS 5 and Jamie's cable but I'm getting some strange results (88590015). I thought the alt map was for the meth tuning but when I increased duty there I got it when the meth kit is turned off (LED off on Jamie's cable). Do I have it backwards?
Tephra, how can I log which map it's running on other than comparing ignition timing / WG duty?
Old Aug 4, 2008 | 04:05 PM
  #859
tephra's Avatar
just a quick reply for Mr...
log 0x8425 - 0 = normal maps, 3 = altmaps
Old Aug 4, 2008 | 04:11 PM
  #860
cossie1's Avatar
Dave is there any news on 90550001 ??
Old Aug 4, 2008 | 04:22 PM
  #861
Mr. Evo IX's Avatar
tephra, sorry to be an idiot but how do I add that to EvoScan, currently it says the Request ID is 40? Where do I put the 0x8425?
Old Aug 4, 2008 | 05:33 PM
  #862
tephra's Avatar
just load it up into a spare MUT request..
if your not using 0x40 then put it in there... then log 0x40 in Evoscan like normal...
Old Aug 4, 2008 | 05:56 PM
  #863
dolphin888's Avatar
Yeah, what's new on that ROM? When we can expect it?
Old Aug 4, 2008 | 06:07 PM
  #864
tephra's Avatar
I am giving cossie a release later today (hopefully)..
so maybe a day or so after he has confirmed its all ok
Old Aug 4, 2008 | 06:12 PM
  #865
Vigman's Avatar
You don't need Jamie's full wiring with an HFS5! Replace Jamie's manual switch by pins 11 & 12 on DDS3 so your map will switch as soon as you turn your WI on...
Cheers.
Old Aug 4, 2008 | 06:15 PM
  #866
Jack_of_Trades's Avatar
Unless they bought my Aquamist harness, which is setup specifically for the DDS3
Old Aug 4, 2008 | 06:18 PM
  #867
Vigman's Avatar
Even better of course ;-)
(no offense, I was trying to help since I thought he already has the regular harness!)
Old Aug 4, 2008 | 06:23 PM
  #868
Mr. Evo IX's Avatar
Jamie, I have your cable for the DDS3, Also we have a V9, but I'm getting some strange results. I went ahead and abandoned ECU Flash 1.29 in case that was part of the problem and am starting with a new version 88590015 XML and version 1.35.
The problem I'm having is it's running the regular WGDC when the LED is on and the meth is spraying and running ALT WGDC when the DDS is off. I think it's also reversing the timing and fuel - go figure. Could you PM me your phone number and help me figure out what is going on? Thanks man, this is going to be the most awesome solution once I get it setup right but it's giving me fits right now and I can't figure it out.
*edit. I'm working up the 1.35 xml / map, as soon as the gf gets home I'll go out and try again and log it all. If I still have the same problem I'll make a new post and take pics, post screenshots / maps, xml's, etc.
Old Aug 4, 2008 | 06:26 PM
  #869
joyce1bro's Avatar
lets go cossie...............
Old Aug 4, 2008 | 06:30 PM
  #870
Vigman's Avatar
Do not know exactly where is the error but are you sure to have the wire bridge on DDS3 between pins 9 and 11??? It looks like you have it between 10 and 11....
