PATCH: TephraMod V5
Old Jul 9, 2008 | 05:49 AM
  #796
Oracle1's Avatar
Tephra,
Can you patch the UK 9 MR as they are different to the other non MR 9's.
The rom/internal ID: 80920002.
I will email it to you with the map.
Please advise!
Top man.
Regards
SK
Old Jul 9, 2008 | 10:50 PM
  #797
ohthree's Avatar
Originally Posted by juyanith
You'll probably want to upgrade to 94170015. I'm pretty sure tephra is trying to cut down on the number of ROMs he has to update each time he releases new features. I just updated my 94170008 ROM for this very reason and it worked perfectly.
to update to a different rom means i just use that rom instead? just copy my tables over and everything will be nifty or is that something extra to do?
Old Jul 13, 2008 | 01:09 PM
  #798
leecavturbo's Avatar
any news?
http://www.keepandshare.com/doc/view.php?id=687950&da=y
http://www.keepandshare.com/doc/view.php?id=687615&da=y
Old Jul 13, 2008 | 05:45 PM
  #799
Thoe99's Avatar
Here's a video clip of Tephra's NLTS action being applied at an autocross:
http://www.youtube.com/watch?v=5JRy3hCxgPs
(yes, I placed 1st in my class )
Old Jul 13, 2008 | 07:09 PM
  #800
fryedchikin's Avatar
I played with the 88590015 Rom today because I am interested in the 2 levels of knock cel flash feature. While doing a couple of logs I noticed something that doesn't seem right....
KnockSum Required for Slow CEL was set to 3
KnockSum Required for Fast CEL was set to 6
CEL on Knock flash time was set to 2000ms
Load Required for CEL on Knock was set to 10
If the KnockSum Required for Slow CEL was reached, the CEL would flash slowly, but if the KnockSum Required for Fast CEL was reached during the 2000ms flash time triggered by the Slow setting, the Fast flash was not triggered.
Old Jul 13, 2008 | 07:25 PM
  #801
RazorLab's Avatar
That is probably because you have the CEL on Knock flash time of 2000ms and the first 3 count of knock was still firing the CEL for 2secs.
I set my CEL time to around 400ms. That way I know if the knock went away during the pull. The 2000ms was driving me crazy because one little knock spike would make the CEL flash during a whole 3rd gear pull, even if it was totally clean after the initial knock spike.
Old Jul 13, 2008 | 07:31 PM
  #802
mitsuatb's Avatar
A/C Software Cut Out
Tephra,
Would it be possible to do a rom feature to cut the A/C under boost or high rpm?
Mitsuatb
Old Jul 13, 2008 | 07:47 PM
  #803
Jack_of_Trades's Avatar
I'm pretty sure the A/C compressor disengages once you exceed a certain load already. Mitsubishi had a hunch people might go WOT with the A/C on,lol.
Old Jul 14, 2008 | 05:24 AM
  #804
fostytou's Avatar
EvoM Community Team
very strange... it definitely has not been a problem for me. My slow gets interrupted by a fast now and then and bumps the speed.
Old Jul 14, 2008 | 06:14 AM
  #805
juyanith's Avatar
As long as you're updating within the same series of ROM that should be all have you do. In my case I just used tephra's 94170015 ROM and copied the data from my941700008 ROM. Just remember to make the appropriate updates for any extra features that you use like 2-byte load/rpm, direct boost control etc. Generally in the 941700XX roms there isn't any difference but it's good to check.
Old Jul 14, 2008 | 06:20 AM
  #806
juyanith's Avatar
Originally Posted by Jack_of_Trades
I'm pretty sure the A/C compressor disengages once you exceed a certain load already. Mitsubishi had a hunch people might got WOT with the A/C on,lol.
I wonder about this (at least for the '03 VIII) since there is a noticeable loss in power if you leave the AC on. I've forgotten to turn it off many times when out getting some logs done. (It's hot here in the summer and I turn the AC on when driving between my favorite "test" spots.) If it truly disengaged the compressor there wouldn't be much difference in top-end power right?
Old Jul 14, 2008 | 07:51 AM
  #807
mitsuatb's Avatar
Hi,
Thanks for your reply.
Seems reasonable to have a factory built in A/C cutoff.
But I have never seen anyone saying that they have seen/ found an actual code that triggers it.
So can anyone say for sure that it exists?
Thanks
Mitsuatb
Old Jul 14, 2008 | 02:49 PM
  #808
There are some new air conditioning logging features with evoscan v2.4, maybe that can help confirm or deny this feature? I'm pretty sure someone on this forum tested it at the harness going into the compressor before.
Old Jul 17, 2008 | 02:41 PM
  #809
ohthree's Avatar
So if I want to switch over to this I will have to copy all my tables over to a different patched rom that people recommend and then just write it to my car?
Old Jul 17, 2008 | 04:41 PM
  #810
EvoDan2004's Avatar
ok here is my little update
who ever followed all my issues and problems will know mainly what im talking about. as of right now everything is working just fine. from the cable to ecu flash. also no more cel light due to the rear o2 sensor. and the v5 patch is working 100% perfect on the evo8 91470015 map. thanks to all thoughs who helped
