PATCH: TephraMod V5
Old Aug 7, 2008 | 06:41 AM
  #886
Colin's Avatar
Tephra what about 8840016/17? I have tested v5.5 (+ accurate boost control mod) and had strange fuel-cuts from 4k rpm up. If you have any good looking version I can manage to test it.
Old Aug 7, 2008 | 06:47 AM
  #887
tephra's Avatar
ummmmm the fuel cuts from 4k where because someone was using a bad acceleration table.. cant remember exactly..
i will be doing a 88840017 5.10 once I think its all ok
Old Aug 7, 2008 | 06:53 AM
  #888
j3llyh34d's Avatar
Hi Tephra, the original ROM ID was 93660005. I was upgrading to 96530006. For the sheer hell (and in an attempt to understand the 'interchangabbility' of software) I experimented with 91470015....
Old Aug 7, 2008 | 06:56 AM
  #889
tephra's Avatar
and going to 96530006?
what maps did you copy across?
what idle problems?
Old Aug 7, 2008 | 07:05 AM
  #890
j3llyh34d's Avatar
I copied everything across. The first time, after disabling the immobiliser (0x56d0) and escaping the Valet mode, the car ran fine, I've never managed to get NLTS work.. but I then copied Ralliart maps into alternate and began playing with boost controll, all behaved well - but the CEL was permanently on.
To be honest, since then I've tinckered with so much I think I should start from scratch. Beginning to doubt myself.......
Should 96530006 work in every way on my car? Am I right in thinking there are known issues? Why does completely disabling the immobiliser need to be done?
Old Aug 7, 2008 | 07:16 AM
  #891
tephra's Avatar
the immob is the only real issue i am aware of.
what was the code associated with the CEL?
Old Aug 7, 2008 | 07:37 AM
  #892
j3llyh34d's Avatar
Codes.....
P0000 Unknown
P0090 Unknown
P0243 Turbo Wastegate Solenoid A Malfunction
P0403 EGR Circuit Malfunction
P0505 Idle Control System Malfunction
Old Aug 7, 2008 | 04:20 PM
  #893
tephra's Avatar
ok 505 you can fix by adjusting your BISS... There is a thread on it by me - fix is on the last page or so...
EGR - does you car have EGR? if not maybe disable it using the FAA bits... not sure which one but search and ye shall find - otherwise post up a new thread
243 - hrmm how are you controlling boost atm?
not sure on the other 2... weird...
maybe wait for 90550001 as that will probably be a better match to your car...
Old Aug 7, 2008 | 05:46 PM
  #894
cossie1's Avatar
90550001 is an evo 7 rom, and he has an evo 8 fq (jdm / uk spec).
Old Aug 7, 2008 | 05:58 PM
  #895
joyce1bro's Avatar
hey cossie when do you think you'll be done with the 90550001 ROM. im eagerly awaiting the patch!!
Old Aug 7, 2008 | 06:02 PM
  #896
tephra's Avatar
when he wakes up
it didn't work first go - but ive sent him a change and hopefully it will work now
once he confirms I will roll in the 5.10 changes (he is running 5.9) and then put it up
Old Aug 7, 2008 | 11:17 PM
  #897
dawnduran's Avatar
Tephra. Would you patch 96530006 with Tephra V5.8 (or later), please?!
I can send you the .bin and .xml
Old Aug 8, 2008 | 02:17 AM
  #898
j3llyh34d's Avatar
Firstly, thanks again chaps - I really appreciate the help
Yes, my car (which I was lead to believe is JDM GSR spec?!) has EGR and ICS. Factory boost control is a single solenoid.
I'm happy to disable (and remove) the EGR system - can't see how it's needed will search on the FAA bits.....
243 - Boost is being controlled by the factory solenoid. It's all standard at the moment - no mods to the "pills". I will ultimately be installing an AVC-R.
Am happy to wait and/or test 90550001......
Old Aug 8, 2008 | 02:22 AM
  #899
tephra's Avatar
hrmm maybe a corrupted rom then..
first time ive heard of codes being throw on my rom's...
maybe try reloading the rom from scratch...
Old Aug 8, 2008 | 02:25 AM
  #900
j3llyh34d's Avatar
Mmmm.... so you would expect this to work without CEL then? I take it disabling the immobiliser doesn't cause a CEL....
If you think it's worth a try, I will start from scratch....
EDIT : I will start from scratch!
