PATCH: TephraMod V5
Old Mar 21, 2008 | 06:17 PM
  #166
fostytou's Avatar
EvoM Community Team
FYI, the 88590015 link is down. If you would like a mirror I have plenty of bandwidth for you
Edit: Seems to be back up already, but I'm still willing to host anything you need me to. I'd love to drop tephra/jack/mrfred a subdomain if needed also. PM me if you want it.
Old Mar 21, 2008 | 06:50 PM
  #167
Jack_of_Trades's Avatar
I've got my own site as a backup if we need it, but thanks for the offer!
Old Mar 21, 2008 | 06:59 PM
  #168
Originally Posted by dolphin888
Another 2 questions today for you:
1) What's wrong with RPM in the boost limit table???
2) How to know what map you are running? I found threee states of my ICS light when pressing auto button:
a) flashing slowly
b) constant flashing
c) no light at all
I think the correct address for the RPM axis is 6DD2 for 94170014. 6B7E is for the 9417008 though. I could be wrong, Tephra will need to confirm if I'm getting better at this Disasm stuff or not,lol.
Old Mar 21, 2008 | 07:12 PM
  #169
dolphin888's Avatar
Well, I couldn't wait answers to my questions more than 5 minutes, so I just copied RPM cells from my original 94170008 to Tephra's 94170014 and... reflashed. Took a spin on the highway - everything looks alright
P.S. Later I changed adress as you wrote, and guess what, you are RIGHT - rpm table looks as it should be so, you are getting better
Old Mar 21, 2008 | 08:43 PM
  #170
fostytou's Avatar
EvoM Community Team
Ok, another simple, slightly confused question
4) Remove your current Hi/Lo Octane Fuel+Timing #2 and #3, only #1 matters anymore
I only see 1 high octane, 1 low octane, and 3x2 octane ignition maps. I realize I'm supposed to get rid of the 2&3 ignition maps, but am I supposed to get rid of the one and only octane maps?
Code:
    <table name="High Octane Fuel Map" address="2dbd">
        <table name="Engine Load" address="6ec8" elements="20" scaling="Load"/>
        <table name="RPM" address="6ea0" elements="15"/>
    </table>
    <table name="Low Octane Fuel Map" address="2ef5">
    </table>
    <table name="High Octane Ignition Map 1" address="33e9">
        <table name="Engine Load" address="6f2c" elements="21" scaling="Load"/>
        <table name="RPM" address="6efa" elements="20"/>
    </table>
	<table name="Low Octane Ignition Map 1" address="3599">
	</table>
(I'm pretty sure the answer is you do need it, as I removed them and they didn't seem to show up.)
Old Mar 21, 2008 | 08:48 PM
  #171
Only remove the maps which have multiple versions so only the #1 map is left.
Old Mar 21, 2008 | 09:07 PM
  #172
fostytou's Avatar
EvoM Community Team
Ok, simple "bug", NLTS load threshold is labeled %, it should probably be labeled load. Going good so far and going to test after I watch lost (I'm an addict!)
Old Mar 21, 2008 | 09:49 PM
  #173
mrfred's Avatar
Changing those cells was a bad move. They for sure are meant to provide control data to some other table. You may not have had a problem in a quick spin down the road, but you could have problems later. I suggest starting completely over.
Old Mar 21, 2008 | 09:57 PM
  #174
draconx's Avatar
that is correct jack. have tephra change that address to 6DD2 on the 94170014.
Old Mar 21, 2008 | 10:19 PM
  #175
Hey Tephra....do what he said,lol.
Old Mar 21, 2008 | 10:20 PM
  #176
I should have the "how-to" v5 installation video uploaded within the hour guys. I yap a lot so no teasing, its hard to remember every detail while the big red 'RECORD' button is glowing,lol. At least it will give most people a good overview of whats involved. I'll finesse the video tutorial when I have time, this will get us by for the moment.
Old Mar 21, 2008 | 10:29 PM
  #177
draconx's Avatar
lol nice jack. thats a good idea. i was thnking about putting up a how-to page. but a video will work just fine .
Old Mar 21, 2008 | 10:43 PM
  #178
draconx's Avatar
well.. it seems that 94170014 for the 94170008 does not work on my 03 . has anyoen else had this problem? do i need to wait for the 008 to come out? (yea i changed everything over. immob. all maps (fuel and timing) and it just cranks.. kinda starts.. (srota) and then just dies. (just die's pretty much).
Old Mar 21, 2008 | 10:46 PM
  #179
The valet RPM limit isn't set below 1000rpm is it?
Old Mar 21, 2008 | 11:21 PM
  #180
fostytou's Avatar
EvoM Community Team
I think this was being discussed somewhere else, but I thought it was going to be integrated here.... Are we able to use the direct boost control mod with V5 yet?
I saw the post about the JDM Map sensor, and of course that is the first step!
