PATCH: TephraMod V5
Old Mar 20, 2008 | 06:02 PM
  #151
High_PSI's Avatar
Are these only for the VIII, anything for the IX?
Old Mar 20, 2008 | 06:07 PM
  #152
Jack_of_Trades's Avatar
Originally Posted by dryad001
So now getting back into the ECU thing again since the spring is near I have a few questions.
Ive done all of the .xml requirements and the new maps show up on my old .bin file, will I still have to transfer all of my old maps to the new one that I downloaded?
Sorry if this was asked already but didn't see it mentioned.
Yes you do. Adding the XML info is nothing more than shortcuts which help you edit things inside the actual ROM. Unfortunately, they point to locations that only exist in the "PATCHED" ROM (.bin file) that Tephra supplied.
Yes they will be offered for IX ROM's too. Not sure if any ROM ID's already listed are for any IX's but I do know you will definitely see some on that list. In order to take advantage of the Map Switching feature, you need some way to switch between maps in the IX's. The IX's that came from the factory with the ISC switch (sorry USDM guys )can just flip from the standard maps and the alt maps via the ISC switch so you really don't need any separate switching device, though some prefer the dedicated switch setup.
The link in my sig shows you how to make your own switching harness or you can just buy one of my pre-made one's if you don't feel like putting on your DIY'r shoes
Old Mar 20, 2008 | 08:25 PM
  #153
Evoryder's Avatar
Originally Posted by bnice01
hmm were you using 0014 I take it with the MUT table?
with or without mut, 2byte didn't work...
neither did map switching. Went back to the ICS switch and everything is fine.
Old Mar 20, 2008 | 09:26 PM
  #154
Hmm, we can't have you wasting a perfectly good map switching harness now. So I take it you never used a volt meter on your install to see if anything was up?
Old Mar 20, 2008 | 11:04 PM
  #155
agron25's Avatar
Originally Posted by Jack_of_Trades
Hopefully I will be uploading the "how-to" VIDEO's tonight so everyone can SEE how to do it, step by step.
Old Mar 20, 2008 | 11:29 PM
  #156
Unfortunately my microphone died on me tonight so I will buy a new one tomorrow and finish up the videos. Hang tight, I'll get it done ASAP for you guys!
Old Mar 21, 2008 | 03:21 AM
  #157
Evoryder's Avatar
correcto
Old Mar 21, 2008 | 03:50 AM
  #158
Well, that doesn't help us find the problem,lol. Still try to get your hands on one when you can. Its probably something silly....always is.
Old Mar 21, 2008 | 06:38 AM
  #159
Evoryder's Avatar
probably is...i'm going to check the adc input again to double check i tapped into the right one. 99% sure, went by your diagram. As far as the 2byte goes...pretty sure it's a rom specific issue. 9417008 works, 94170014 doesn't...
Old Mar 21, 2008 | 10:50 AM
  #160
John F's Avatar
I've been trying out 96530006 today and I'm sure there is a problem with Alt Map boost control. I've just switched from using my Apexi AVCR boost controller to try out ECU boost control using the AVCR solenoid. I managed to get the boost pretty steady at 1.65 bar in all gears but when I try alt map with the same settings the boost just goes wild, 1.95bar at 3000RPM in 5th. I've seen it go to 2.2 bar before I've let off the gas. The same thing happens even with reduced duty cycle in Alt Map. I didn't take any logs and I probably won't be able to do any more testing for the next few days as the weather is turning really bad.
Old Mar 21, 2008 | 10:58 AM
  #161
ciobing's Avatar
NLTS don't work?
Old Mar 21, 2008 | 11:09 AM
  #162
John F's Avatar
Originally Posted by ciobing
NLTS don't work?
Just tried it out and it works.
Old Mar 21, 2008 | 11:34 AM
  #163
Did you set it so the ADC input was set to switch the maps, instead of the ICS switch in the Tephra Mod Options table????
You can only use one or the other, not both.
Old Mar 21, 2008 | 05:06 PM
  #164
dolphin888's Avatar
Another 2 questions today for you:
1) What's wrong with RPM in the boost limit table???
2) How to know what map you are running? I found threee states of my ICS light when pressing auto button:
a) flashing slowly
b) constant flashing
c) no light at all
Old Mar 21, 2008 | 05:46 PM
  #165
Evoryder's Avatar
sure did. Dave did stress that...
