PATCH: TephraMod V5
Old Mar 22, 2008 | 02:13 PM
  #196
2k4EvoVIII's Avatar
Originally Posted by Jack_of_Trades
Watch the HOW-TO VIDEO HERE!!!!!
Right Click Image to "Save As". File Size: 81Mb Duration: 18 Min.
I also hosted it on www.Streetfire.net tonight which will be a smaller, easier to "stream" file for anyone who doesn't want to DL the FULL LARGE version (my version is larger and easier to view compared to the streetfire version).
here's the streetfire link:
http://videos.streetfire.net/video/9...670102c864.htm
Jamie:
You are the man bro! I know you spent allot of time to make this easy and possible for the community and you did a great job! Keep up the good work!
Chris
Old Mar 22, 2008 | 02:32 PM
  #197
fostytou's Avatar
EvoM Community Team
Can I ask what parameters you guys are using for your NLTS? I dropped mine down to 100 load and 80% throttle and I seem to get one quick bounce and then it still revs. Also, I don't know if it makes any difference but I set mine up similar to dsmlink with a 3500RPM drop window.
I checked mine by setting it to 0mph, 0 load and it is definitely working there, but on the road it doesn't seem to keep doing its thing.
I can't tell if I'm just being scared and lifting just enough or what. I have it in my 2g and it was never a problem, but I was probably less worried about blowing a tranny in that car.
Old Mar 22, 2008 | 03:03 PM
  #198
Jack_of_Trades's Avatar
I set mine for a 1000rpm drop, 100 load, 95% tps. Everyone who first used the NLTS in his previous patches had experienced the "punch in the chest" feeling by slightly resting your foot on the clutch pedal and reactivating the NLTS just after you had made a gear change.
Old Mar 22, 2008 | 03:18 PM
  #199
agron25's Avatar
im today test
my set mine for a 800 rpm drop,0load;98%tps;0km/h
Old Mar 22, 2008 | 04:40 PM
  #200
fostytou's Avatar
EvoM Community Team
Originally Posted by agron25
im today test
You will probably want to bring your load and speed up after the test... I'm not sure if that was clear or not
Old Mar 22, 2008 | 06:15 PM
  #201
rish197's Avatar
I just wanted to double-check. I have the new harness and since I already have my car apart, I wanted to install it. Since I don't have a V5 rom yet, is it okay to have the harness hooked-up without it? It should just sent a signal to the ECU, but not do anything, right?
-Jason
Old Mar 22, 2008 | 07:27 PM
  #202
fostytou's Avatar
EvoM Community Team
-Jason
If you hook up the harness you will be 100% fine if you don't switch it to on, just set alternate maps to ADC0F=1 (you may be ok setting it to 0 also, but either way best if you don't flip the switch until your maps are in.)
FYI, I rocked the NLTS on tonight with a little more open road and it worked flawlessly. I'm planning on lowering the drop RPM (1650 is looking like a good amount from my logs) a bit and possibly adjusting the clutch sensor a bit. The car falls flat on its face for a second as the clutch is re-engaging and the limiter is still active. It helps to dump the clutch harder on the shift, but since I still have a pill I don't think it can quite make it out fast enough.
It is a really good idea to use the test to get a feel for when the clutch sensor would dis/engage. I've heard alot of those stories on the DSMLink forums and it seems like the best idea is to just make sure you are actively on the dead pedal. Its a good lesson though, because like the trigger of a gun your foot shouldn't be on the clutch unless you are using it
Old Mar 22, 2008 | 07:44 PM
  #203
bnice01's Avatar
OMG that crap is a crazy feeling when you do it by mistake or when the person you flash there car doesnt realize how senstive there clutch switch is.
Old Mar 22, 2008 | 09:58 PM
  #204
YEah, I highly recommend any NEW user of the NLTS feature sets there TPS to 20%, KM/h to 0, load to 0 and rpm drop to 1000rpm. Then rev the car to 2500RPM while parked and simply rest your foot on your clutch pedal (BARELY touching the rubber pad with your shoe) and slowlllly start applying pressure to see how LITTLE you need that pedal to be depressed.
Its definitely good to teach yourself how sensative your clutch switch really is.
Old Mar 22, 2008 | 10:28 PM
  #205
http://videos.streetfire.net/video/H...all_154889.htm
Originally Posted by 2k4EvoVIII
Jamie:
Chris
Thanks man. I remember how hard it was to get my feet wet with this stuff when I started so I figured I'd make the learning curve a bit easier for the new guys
Old Mar 22, 2008 | 11:07 PM
  #206
Originally Posted by draconx
that is correct jack. have tephra change that address to 6DD2 on the 94170014.
Now that I think about it, the Patch doesn't have anything to do with the boost limit table addresses. It must be an ECUFlash XML error. I run v1.34 and I had the incorrect Boost Limit RPM address of 6B7E (thats the 94170008 address) so I had to change it to 6DD2. Again, not related to the patch, its an ECUFlash XML error.
Old Mar 23, 2008 | 12:08 AM
  #207
agron25's Avatar
yes
i was my first test
I m going to change the load and the speed then
Old Mar 23, 2008 | 04:20 AM
  #208
agron25's Avatar
What is that is normal that I find these values
the probleme baterry voltage ? or good ?
thank
Old Mar 23, 2008 | 05:08 AM
  #209
ciobing's Avatar
thank
the right address of the injector battery voltage latency is 37c0.Check in your 96530006 xml file.Check "Desired Idle RPM-Neutral"(address 426c) and "Desired Idle RPM-Drive"(address 427a) too
Old Mar 23, 2008 | 06:25 AM
  #210
agron25's Avatar
i have these address in the xml ,but not work not
