PATCH: TephraMod V5
Old Mar 18, 2008 | 05:04 PM
  #76
Evoryder's Avatar
Originally Posted by tephra
Hey Jeff,
Can you log 0xFFFF8425 in a spare MUT?
0 = should standard maps
3 = altmaps
Cheers
D.
don't know how to go about logging. Where do I add that?
Old Mar 18, 2008 | 05:07 PM
  #77
Jack_of_Trades's Avatar
Are you using the 3D MUT Table? and do you use Evoscan?
  #78
BaLListic_EVO's Avatar
i used an earlier version of this but i had issues and had to quit using it. Apparently my tuner hex edits somthing that is not visable Via ECU flash. Is there somthing that i can paste into my current map so that i dont have to copy over all my stuff?
Old Mar 18, 2008 | 05:10 PM
  #79
Evoryder's Avatar
no and no
maybe this is obvious, but have you changed the ecu flash option to "developer?"
Old Mar 18, 2008 | 05:12 PM
  #80
draconx's Avatar
hey tephra, why no 94170008 ?
Old Mar 18, 2008 | 05:13 PM
  #81
Evoryder's Avatar
use 9417004 ...same as 9417008(my original rom id) ...they did mention earlier on this the post or some other post?
Old Mar 18, 2008 | 05:32 PM
  #82
MR Turco's Avatar
Yes you can remove #2/#3 BDEL's as well!
The O2Sim is the same algorithm as MrFred but implemented slightly differently
Cheers
Dave.
Ahh I underestimated the sneaky sir. Thanks Dave.
Old Mar 18, 2008 | 05:37 PM
  #83
Evoryder, add this to your 94170014 XML, just above the </rom> at the end of the file.
Code:
<table name="MUTE3" address="384e6" type="1D" level="4" scaling="Hex16"/>
<table name="MUT83" address="38366" type="1D" level="4" scaling="Hex16"/>
Enter 0x8425 into MUTE3
Enter 0x8929 into MUT83 (might already be set to that value)
This is the code for evoscan to log them. Not sure what you might need to change for Mitsulogger if thats what you use.
Code:
<DataListItem DataLog="N" Color="" Display="ALT MAP Activation" LogReference="AltMapActive" RequestID="E3" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="Alt Map Activation. 0= Standard Maps 3= Alt Maps" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="ALT Map Input Voltage" LogReference="AltMapVoltage" RequestID="83" Eval="(x/256)*5" Unit="Vdc" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="15" ChartMin="0" ChartMax="15" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Mar 18, 2008 | 05:42 PM
  #84
MR Turco's Avatar
Yes - sorry I should say:
With regards to "removing" 2/3 (timing/bdel/bwgd) its upto you, but probably renaming the table to something like "original name + DONT USE" might be best.
That way you can still "see" it, but you get a visual reminder not to use it!
Cheers
D.
I just commented it out in the definition files that way i can easily revert if i need to.
This forum has forced me to become extremely familiar with ECUflash definitions.
Old Mar 18, 2008 | 05:46 PM
  #85
cossie1's Avatar
Code:
Code:
What does this do ?
Old Mar 18, 2008 | 05:48 PM
  #86
MR Turco's Avatar
Originally Posted by cossie1
What does this do ?
it is the Evoscan definitions to log if the alternate map is activated.
Old Mar 18, 2008 | 05:55 PM
  #87
cossie1's Avatar
is it the same code for all roms ???
Old Mar 18, 2008 | 06:14 PM
  #88
I would guess that its not. I think the MUT83 location MIGHT be but I really haven't looked too far into it.
Old Mar 18, 2008 | 06:23 PM
  #89
tephra's Avatar
Yeah MUT83 should be universal!
Old Mar 18, 2008 | 06:37 PM
  #90
cossie1's Avatar
Added them in, both were showing FFFF (this sound correct ?).
Have now changed them to the above (8425 and 8929)
