PATCH: TephraMod V5
Old May 29, 2008 | 06:49 AM
  #661
TouringBubble's Avatar
88590013, 14, and 15 all work for USDM IXs from what I've found ... I agree that it would be a good move to go ahead and update everyones ROMs and only patch the newest ROM for the model.
Is there a list anywhere of the ROM compatibility?
Old May 29, 2008 | 07:04 AM
  #662
tephra's Avatar
taav - set the speed threshold to 0 so it activates when parked...
what do u mean you can lower it?
Old May 29, 2008 | 07:18 AM
  #663
taavisev's Avatar
I cant set it 0 only can set it higher than 30. its like the minus(only can go up with speed number no down) doesnt work.
Old May 29, 2008 | 07:37 AM
  #664
taavisev's Avatar
ok i it worked on test mode!
but still it does not work on high load!!! I have a log for 1 gear change RPMS stays in same place where i press the clutch
Old May 29, 2008 | 07:38 AM
  #665
scheides's Avatar
EvoM Moderator
Tephra, any possibility of doing 96420008 ? Trying to help a friend get the hacked goodness on his car
Old May 29, 2008 | 08:23 AM
  #666
tephra's Avatar
taav - can you attach the log?
scheides - maybe in the "near" future probably as part of 5.8
Old May 29, 2008 | 08:29 AM
  #667
taavisev's Avatar
i dont know to u get anything from that put i try!
thanx
Old May 29, 2008 | 09:48 AM
  #668
Viciouslord's Avatar
I am going to release V5.8 real soon, over the next week or so, it will include a few fixes for things that are buggy as well some some minor new features.
I want to get peoples feedback about ROMID upgrades. Are people happy with the following:
88580013 -> 88580014 (confirmed by me :P)
88590013, 14 -> 88590015
94170008, 14 -> 94170015
88840013, 14, 16 -> 88840017
Any other ROMID's that I can put on that list? Or any objections to the ROMID's on that list?
can you do some kind of write up on how to perform this "ROMID upgrade"...
i tryed to do this a couple of times but failed. thanks again
i currently have 94170008.
Old May 29, 2008 | 12:31 PM
  #669
In most cases, you simply DL the new ROM version, copy over your immobilizer code and flash. Of course, you need to copy over any modified tables as well.
The only odd ball is switching from the USDM '05 ROM to the EDM '05 ROM which requires disabling the immobilizer.
I recently upgraded a 94170008 to a 94170015 and had no issues. I added the JDM MAP, direct boost control, MUT table, Tephra mods, lean spool, etc to it as well and all work fine so far. That's the hardest part of upgrading the ROM after it's tuned ... some of these tables you've modified/added may keep the car from running properly if you forget one. I know that my car won't run at all on the stock ROM anymore because of the MAP/direct boost control tables.
Old May 29, 2008 | 05:13 PM
  #670
tephra's Avatar
when upgrading you should ONLY copy tables that you changed from stock.
ie if you accelerator enrichment table LOOKS different BUT you did NOT change it then DONT change it in the new version.
Old May 29, 2008 | 07:46 PM
  #671
fixem2's Avatar
upgrade path 96940011>>>96530006 (immobilizer disabled)
Old May 30, 2008 | 01:36 AM
  #672
SoCalRedLine's Avatar
94170014 - V5.1
I tested this mod on a 94170008 - 2003 Evo last night, and it would not start after ALT map was engaged.
Car started fine with initial flash, and 2 subsequent starts. Also, would not start after disengaging the ALT map. NLTS, Valet worked just fine tho.
Re-flashed back to 94170008 and the car started just fine.
...Just reporting what happened to me. Im going to be trying the 94170015 - V5.1 next and see what happens.
Thanks for all the support Tephra!!
(im guessing this has to do with the immobilizer... any help?)
p.s. Ive been running the 88590015 V5 for 15k miles now, everything works just fine (except the NLTS bug w/ load)
Old May 30, 2008 | 01:56 AM
  #673
tephra's Avatar
altmap by autoics or adc0f?
what happens if you start on normal maps then switch to altmaps? (just idling)
I suspect your injector scaling is whack... ive had that before, forgot to do the IS and car wouldn't start/run/stank of gas :P
but yeah upgrade to 15 neways
Old May 30, 2008 | 02:04 AM
  #674
^hmm... lemme check the tune, im almost 100%certain i checked that on the tune.
(ill pull it up here in a sec)
it was using the ICS and during idle it worked fine, then we turned the ALT map state back to normal and shut off the car. On the next shot the car wouldnt start. I tried enabling the ALT map and then disabling it, no change in starts. Re-flashed the V5 tune, and it still wouldnt start. Swapped back to his original flash and everything was working just fine again.
Old May 30, 2008 | 02:07 AM
  #675
just checked the ROM, and its there 513. its a bone stock 2003, with only 3-bar MAP and 3-port (my installing and tuning )
p.s. is this your normal time you spend online?
