PATCH: TephraMod V5
Old Jun 25, 2008 | 04:53 AM
  #721
GobbleTek's Avatar
Any update on 90550001? I've got an 8 ECU flashed with 90550001 installed in my Evo 6 TME but am still getting the P0135 O2 heater DTC. Will this v5 patch address this?
Or, does anyone know where in the ROM to disable this code? I'm not looking for the Tephra patch functionality if I can just disable it some other way.
Old Jun 25, 2008 | 05:37 AM
  #722
tephra's Avatar
what's P0135?
Old Jun 25, 2008 | 05:43 AM
  #723
GobbleTek's Avatar
Originally Posted by tephra
what's P0135?
P0135 Heated Oxygen Sensor Heater circuit Bank 1 Sensor 1
Old Jun 25, 2008 | 05:07 PM
  #724
tephra's Avatar
is that the front 02?
how have u disabled the rear02?
Old Jun 25, 2008 | 05:20 PM
  #725
RazorLab's Avatar
I had a problem with 96530006.
Got a CEL for "idle control failure" or something like that, can't remember the exact code off the top of my head.
I'm going to see if I can replicate it on my personal evo here soon...
Old Jun 25, 2008 | 06:05 PM
  #726
logic's Avatar
You know, I've gotten that as well (on 96530006 vs. 96940011), but it only started happening after putting in the 880s, and I was fighting some idle issues with them initially.
I haven't thrown that code since I got the injectors dialed in properly.
Old Jun 25, 2008 | 06:12 PM
  #727
RazorLab's Avatar
Well this Evo had stock injectors and putting it back to 96940011 didn't bring the code back so...
Old Jun 25, 2008 | 06:18 PM
  #728
RazorLab's Avatar
logic, did you copy over your ISCV and Idle Stepper values from 96940011 to your 96530006 rom or did you keep the (different) values in the 96530006 rom?
Old Jun 25, 2008 | 06:36 PM
  #729
tephra's Avatar
i would think you leave the stock ones alone - there shouldn't really be a need to change them..
Old Jun 26, 2008 | 01:06 AM
  #730
evo828's Avatar
The Idle control malfunction code is usually thrown when your setup is not allowing the ECU to maintain idle with around 20 steps on the stepper ((without AC). If it is far away - then it throws this code. Log your idle steps at idle when engine warmed up and no further load (no AC, no turning the wheel - servo).
Old Jun 29, 2008 | 06:59 PM
  #731
Thoe99's Avatar
What are the differences between 94170008 and 94170014 (or 15)?
Old Jun 29, 2008 | 07:23 PM
  #732
gsrboi80's Avatar
14 and 15 were factory P0300 code fixes. So you can use either in place of your 08 rom.
Is/has 94170015 - V5 tested to be good. I need the rear 02 patch so I can log my NGK wideband
Old Jun 30, 2008 | 01:55 AM
  #733
Inprogress's Avatar
Sorry if this has been answered already, but 2 byte load is still logged through Evoscan even when using this mod right? Does it still show up in Ecuflash?
Also, I am copying the new XML code right over the old V3 patch stuff right? And removing the timing maps, etc
Old Jun 30, 2008 | 06:40 AM
  #734
gsrboi80's Avatar
Yea just make sure you have the code in you XML for the 3D MUT Table and edit the appropriate values for 2-Byte Load
Old Jul 1, 2008 | 05:05 AM
  #735
lan_evo_mr9's Avatar
Is the patch (88590015) compatible with vista? The reason I'm asking is because I'm unable to save the file after cutting/pasting. I was able to do it on my friends XP version though. Any ideas or suggestions on what I need to do would be greatly appreciated.
