PATCH: TephraMod V5
Old May 18, 2008 | 02:14 AM
  #601
sub7's Avatar
Thanks dave! Hope to get the final revision soon
Old May 18, 2008 | 02:50 AM
  #602
tephra's Avatar
Ryan - just use the one that is working for you.
I am going to make the same change to the one in this thread...
Old May 18, 2008 | 04:14 AM
  #603
kkarim's Avatar
Tephra, should i log 0x8425 to see which map i'm using, or is it different for the 88840017 rom?
Old May 18, 2008 | 05:08 AM
  #604
tephra's Avatar
its universal
0 for normal, 3 for altmaps
Old May 18, 2008 | 05:15 AM
  #605
kkarim's Avatar
ok cool.. thanks a lot.
sorry for the O/T, but could you have a quick look at my rom to try and remove the -10 degree timing limit?
i'd really appreciate it.
Old May 19, 2008 | 08:00 PM
  #606
lemmonhead's Avatar
how come when vallet mode is 0 (disabled) if you press the gas peddle down with on ignition it sill clicks like its trying to go into the mode?
Old May 19, 2008 | 08:15 PM
  #607
tephra's Avatar
it shouldn't...
what happens with the CEL?
Old May 19, 2008 | 08:54 PM
  #608
kstpeter33's Avatar
any word on 94170008?
Old May 19, 2008 | 09:09 PM
  #609
tephra's Avatar
upgrade to 14 or 15
Old May 19, 2008 | 10:01 PM
  #610
kstpeter33's Avatar
probably a stupid question but how do i do that? just download 94170014 or 15 instead and copy/paste into the 94170008 file?
Old May 19, 2008 | 10:14 PM
  #611
tephra's Avatar
copy all your settings (fuel/timing/leanspool/immob/boost) into V5 of 94170015 and then flash that to your car...
Old May 20, 2008 | 10:42 AM
  #612
kstpeter33's Avatar
ah ok, ty...great mod btw
Old May 20, 2008 | 11:07 AM
  #613
lemmonhead's Avatar
i never tried to disable the cel, but for sure if you disable the valet mode, it still sounds like its going into it. I havn't verified if it actually worked but you can hear the sound of the ecu clicking.
this is for 2006 015 ROM
Originally Posted by tephra
it shouldn't...
Old May 20, 2008 | 05:51 PM
  #614
tephra's Avatar
but does the CEL flash like it would when enable/disabling the valet mode (when enable valet = 0)
Old May 21, 2008 | 10:27 AM
  #615
lemmonhead's Avatar
nope it does not flash, i tried it this morning. When i get home from work I will set the rev limit to 2000 and boost down low and test it just to make sure it dont work with " 0" entered in your table.
if it dont work, do you know why it would make that clicking sound?
