faint fuel smell in cabin during pulls
Old Mar 29, 2008 | 06:18 AM
  #31
TearItUpSports's Avatar
I don't know if you have the same emissions equipment there, but I had this same thing happen when I was messing around with the charcoal cannister by the rear bumper...I had removed the valve from inside the frame rail, and it was coming in through the trunk (boot for you) of the car (I have no rear seats).
Check all the rubber hoses around your fuel tank.
Old Mar 30, 2008 | 06:48 PM
  #32
tephra's Avatar
argh - its gotta be the o2 housing -> down pipe.
still getting exhaust smell + soot on the front of the rocker cover
It looks like the donut gasket isn't making a good seal with the down pipe.
I guess I will need to take it to an exhaust shop to check out?
Cheers
D.
Old Mar 30, 2008 | 07:32 PM
  #33
mrfred's Avatar
Is your new DP made to be used with the donut gasket? (Some are not.)
Old Mar 30, 2008 | 07:55 PM
  #34
Jack_of_Trades's Avatar
My car came with some "T-Pro's" DP (which the fitment SUCKS) and it uses 2 o-ring type flat gaskets, same metal gasket material you use at the cat.
Evolpixy
May 11, 2017 11:26 AM
chewyobaca
158
Aug 20, 2016 08:59 PM
Yanluvralliart
Apr 29, 2014 08:20 AM
Renley
Sep 7, 2011 07:43 AM
zlancer
Lancer Aftermarket Forced Induction Tech
Sep 25, 2002 10:27 AM
